Stock Windshield Washers Have Low Pressure/Aim Low
Old Jul 14, 2005 | 07:09 PM
Supercross's Avatar
I'm not sure if this is a common problem or not but my stock windshield washers seem to have low pressure because they don't shoot water very high on my windshield at all. I've tried aiming them but it just seems theres not enough pressure. Does anybody know any tricks to increase the pressure or anything that will allow the water to be shot higher on the windshield? Thanks
Old Jul 14, 2005 | 07:10 PM
AscendantMax's Avatar
are they clogged with calcium/mineral deposits?
Old Jul 14, 2005 | 07:18 PM
Supercross's Avatar
I'm pretty sure they're not but I can check. I had actually put some colored nozzles on for a while, but they had absolutely no pressure at all, so I had to go back to my stock washers. These are better but still not as high as it should be.
Old Jul 14, 2005 | 07:23 PM
i'd take them out, and dump them in a warm water/vinegar solution (or warm water and lemon juice) so the acid can get rid of the deposits. then i'd check the lines itself to see if they're cracked. you might be losing pressure that way.
Old Jul 15, 2005 | 02:31 AM
Wiking's Avatar
Originally Posted by Supercross
... higher on the windshield? Thanks
Your pump is starved. No way but take it out, clean/replace connectors &wirings.
Easy DIY: New wire from batt to a add on relay; use 'ol pump supply as input for this relay coil.
Buy, install aftermarket pump.
Old Jul 15, 2005 | 04:33 AM
internetautomar's Avatar
mod or sell?
I need to partially agree with wiking.
make sure the pump is getting it's full 13.8 volts
Old Jul 15, 2005 | 04:37 AM
Wiking's Avatar
...an I guess u can get good pwrFull aftermarket pump from ia-shop?
edit:
w/o actual measurement, I guess currently theres smtg like 6Volts at the pump; when pump runs. Taking in account the long wiring (fifty feet? with gnd ret wire), switches, connectors and fusing resistance, the voltage will never go over 11 even in new car. That drops to ten ? as pump sinks pwr...
Smbdy interested, pls do the actual measurements...
Old Jul 15, 2005 | 09:55 AM
eric93SE's Avatar
I've replaced my pump before. I'd reccomend simply unpluging the power plug and cleaning both ends with alchol. Nissan used some grease to prevent oxidation, and that grease is all stuck in the connector giving poor contact. From what I remember, the connectors are gold plated.
also use the wire from a resistor or capacitor to clean out the nozzles on the hood.
Old Jul 15, 2005 | 05:22 PM
maximal's Avatar
i remember when mine were clogged with wax. i used alcohol and a q-tip to try to clean it off. when that didn't work, i took a needle and poked it through the holes...after that, the fluid shot clear over and hit my roof/trunk!
Old Jul 22, 2005 | 09:45 AM
jkmay01's Avatar
Lil 8
i have the same prob i just had my mechanic at the time just un hook the hoses leading to the nozzles and blow the nozzles with a air compressor works good now, but check your feed lines they could be clogged
Old Jul 22, 2005 | 09:48 AM
Wiking's Avatar
I suppose there is some kind of screen [May be clogged in June?] in the water intake?
Old Jul 22, 2005 | 09:18 PM
MyBlue92Maxima's Avatar
how do you pop the spray nozzles out , wheres the pin things to push , in the hood i cant get my hand anywhere neer the nozzles , i tried with plyers but theres nothing to grip onto..i want to clean mine too
Old Jul 22, 2005 | 09:32 PM
Supercross's Avatar
I just used some needle-nose pliers to squeeze the washers from underneath. The washers snap into place by two notches on opposite sides. You'll figure it out.
9aj9
Apr 5, 2020 12:11 AM
BkGreen97
Apr 2, 2016 05:47 AM
02PearlSE
Feb 1, 2016 12:37 AM
Excalibur23
Oct 13, 2015 04:33 PM
TheMafia
Sep 4, 2015 08:26 AM
