Power steering fluid leak????
Old Jul 20, 2005 | 07:12 PM
Travis92se's Avatar
I have noticed that I have a lot of fluid around the power steering pump and at first I thought that I have a leak. Now, I remember that I changed the fluid about a year ago, but I was lazy. I just unplugged the hose from the tank and let it drain all over the engine. I have not drove the maxima but maybe a thousand miles, tops, since then. I know that the rear valve cover is not leaking because I changed it about a month ago. Do you think that draining the fluid all over that side of the engine over a year ago would still look wet like this. Again, I haven't drove it much since then due to other problem but I am trying to determine if something else is leaking in the area. I believe that the front crank seal is leaking also but would it splash all over the power steer pump?
Old Jul 20, 2005 | 07:15 PM
fatboyslim86440's Avatar
my power steering was leaking about a year ago
all i had to do was replace a hose and runs great now
sorry if i couldnt help you any more
Old Jul 20, 2005 | 09:16 PM
kcidmil's Avatar
I think the only way you'll ever really be able to find out is to clean it. Simple Green will clean just about anything off.
lowpost99
Oct 26, 2025 06:53 PM
sctludwig
Sep 1, 2022 01:32 PM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
coasterswim
Sep 2, 2015 07:43 AM
