CV boot ???
Old Jul 23, 2005 | 10:41 PM
floods943's Avatar
CV boot ???
I was changing out my brake pads today and I noticed the left CV boot was ripped about 1/3 of the way around on the bottom half, with grease all the way around the ripped area.
My question is: How serious is this; and are there any write-ups or clever methods to seal this rip without having to purchase new materials. I'm nearly broke as it is, so I hope this isn't a major concern. I've noticed nothing abnormal while driving.
Old Jul 23, 2005 | 11:57 PM
Minty91GXE's Avatar
if there is a rip and grease coming out, your CV joint is going to fail soon afterword. you'll get a 'click-click-click' sound when you turn your wheel. you can pull the axle and repair the CV boot (~30-40$ or therebouts- rough guess) but its a big pain and very messy. OR you can just swap in a new axle... much easier, slightly more costly. for your car they sell for about 60-70 $ on ebay. i've never heard of anyone just sealing the rip - as in i dont think thats an option.
tom
Old Jul 24, 2005 | 01:38 AM
Phatsta's Avatar
No repairing the crack is a bad option if it even is an option...
It's really not that difficult to replace the boot. Just turn the wheel and listen to that which Minty describes... the click-click. If you can't hear any then your axle is fine and a boot replacement is the only thing you need. Inspect both sides.
The hardest part is the wheel hub nut. Alias the drive axle nut. It's a 32mm nut that will sit very tight, but as long as you can get that away the rest should be a piece of cake. Also consider changing the ball joint and control arm bushings while you're at it, it'll save you the job another day, plus the car usually feels much better to drive.
I don't know, cost-wise, what the difference is over there but over here you pay something like $40 for a boot replacement kit while you'd have to pay $300+ for a new axle.
Here's a guide that includes taking out the CV axles, follow that until point 3, EXCEPT the 'preparation' part. You won't need to remove your hood to do this job . http://www.cardomain.com/ride/749143/2
Old Jul 24, 2005 | 03:45 AM
Phatsta's Avatar
I just finished a guide just for this job. Here you go.
http://www.cardomain.com/ride/749143/8
Old Jul 24, 2005 | 05:12 AM
internetautomar's Avatar
mod or sell?
Depending on how mechanically inclined you are, the boot is cheaper (like $10-20) vs doing the axle ($60-80), but the axle may be a ***** to get out and if you're creative, you can do the boot with one side of the axle still installed.
I don't have a write up on it, because I haven't done it. I find it easier/quicker to just do the whole axle.
Old Jul 24, 2005 | 05:25 AM
tripleGmax's Avatar
i thought it might be less messy to do the whole axle, but then the tranny fluid that spillls everywhere cancelled out that. but the fact that regreasing an axle and putting a new boot on isnt nearly as good as just swapping a new axle in. so i vote for new axle. just hope you can do it yourself, i got quoted 350 from midas one time when i went in there one time(i did it myself saving over 200 bucks)
Old Jul 24, 2005 | 07:15 AM
MrSector9's Avatar
defiantly just replace the axle is my best advice. I had a cracked boot and just replaced the boot/regreased the unit and a coupel weeks later it started clicking... so my advice is replace to axle and be done with it.for the extra money and time i wish i had of replaced the whole unit cuz now i gotta take it all apart anyway.. AGAIN
BJ White
Old Jul 24, 2005 | 07:45 AM
Phatsta's Avatar
You could definatly change the boot without emptying tranny fluid, but it's a bit more tricky. You could always remove the clip in place, leaving the inner axle housing in the tranny. I did the first time but since it's like 10 times easier servicing them when they're out I prefer doing so.
It is definatly better to replace the whole axle. As long as you can afford it. If the price difference over there is no more than $40 - $60 I say hell go for it!
Old Jul 24, 2005 | 07:48 AM
floods943's Avatar
Much thanks, sir
Old Jul 24, 2005 | 07:50 AM
floods943's Avatar
Haha, who knows. I'm at 150,000 with the auto right now, I'll probably have to be doing that soon anyway.
Old Jul 24, 2005 | 08:26 AM
Will's Avatar
I just did my axles too when my boots tore; I figure that after 12 years, they could have used new ones. If you are very broke and don't drive long distances floods, just drive the car as is until you hear clicking. It may last a few weeks, or I've seen a few months, but start saving until it clicks. Worse that can happen are that your axles pop out, but that is unlikely and you just have to keep an ear on them. G'luck.
Old Jul 24, 2005 | 04:46 PM
bvtran's Avatar
94c Big Max
get yourself a cheap pump for $5, pump out your tranny fluid then change the axle. when you're done, pump it back. it's much more cost effective.
Old Jul 24, 2005 | 09:38 PM
Alex_V
Or you could change it since its been 100K on the same fluid (come on you know you cant remember the last time its EVER been changed...)
~Alex
Old Jul 24, 2005 | 10:24 PM
aminus21's Avatar
pump??? ATF costs around $1-2 a quart, and the it's as easy to drain, as the oil. Plus it should be changed every 30k.
Drian the ATF, and change the whole axle..should cost you $40-$70 depending on where you get your axle from. Dont forget to also change the axle seal, if it is damaged. Most people just change it anyways as preventive mainteanace, so you're not leaking ATF after a week..
my 2 cents.
Old Jul 25, 2005 | 12:41 AM
Wiking's Avatar
...It is definatly better to replace the whole axle. ...
And easier. And replace also the tranny/axle seals, few dollar$ apiece.
There is/was one supplier advertizing a boot rubber so flexible that it can actually be drawn over the joint. Now where can one buy those?
Old Jul 25, 2005 | 01:38 AM
Phatsta's Avatar
Have no idea. I bought mine at Mekonomen and those weren't even a bit flexible.
There are those spilt boots as well that you don't need to take down anything for. You just put it on and glue it together. My dad used one of those once and it tore in about a month. Useless.
Old Jul 25, 2005 | 06:25 AM
mod or sell?
Old Jul 25, 2005 | 06:36 PM
bvtran's Avatar
94c Big Max
my 2 cents.
argh man, you're right. I guess I am the only guy treating my car with all synthetic... I paid $8/qt. if you're using cheap oil, then just dump it and refill when you're done replacing your axles.
knight_yyz
Nov 1, 2015 01:34 PM
londonflu
Sep 19, 2015 02:33 PM
followthadollar
Sep 17, 2015 06:31 PM
Bonka
Sep 14, 2015 11:18 PM
