need some suggestions
Old Jul 26, 2005 | 12:43 PM
TheGreat's Avatar
Okay my max is running real rich and I was wanting to know if you guys could direct me in what direction to start checking problems it could be cause its gotta be fixed the gas smell is about to kill me and the smoke is not good so guys any help would be great
Old Jul 27, 2005 | 02:43 AM
Greeny's Avatar
¯\(°_o)/¯
Is your "check engine' light coming on? If so, pull the codes.
If not i would say check injectors......
Old Jul 27, 2005 | 03:20 AM
Wiking's Avatar
Originally Posted by TheGreat
Okay my max is running real rich ...
Real rich or just not burning? Its easy to check ign stuff before swapping injectors; in any case they must be serviced periodically: plugs, cap, wires. And IF u want best spark, u'll make real wires. [this will not correct possible bad injectors, however]
Dont forget harness PM: http://www.cardomain.com/ride/748507/14
Old Jul 27, 2005 | 05:36 AM
vansskaterfreek's Avatar
ho do you make oyur own wires, and what do you make them with, plugs, and what guage wire? were to find the wire too.
Old Jul 27, 2005 | 06:12 AM
Wiking's Avatar
- check the http://www.cardomain.com/ride/748507/12
- wire gauge: special spark high voltage wire, gage meaningless
- sorry, need some resistors to suppress radio interference. There are resistors that u can install between the wire (screw in both ends) but for some reason the salesmen takes 20x price each compared to plug (why?). Try to get them or plug caps with 1k resistors (5k work though)
- spare shops sell by the meter 3m (10ft) ok for VG
- actually I should search for the net, all the time friends beg me to make 'em...
- will last longer than car, min 10yrs.
- 1/3 cheaper (lots handiwork) than std soot bags
Old Jul 27, 2005 | 06:49 AM
bhunter's Avatar
Did you just call our beloved Wiking a Ho?
Old Jul 27, 2005 | 08:59 AM
Greeny's Avatar
¯\(°_o)/¯
Old Jul 27, 2005 | 09:27 AM
Wiking's Avatar
hoho!
Did couple hours seek on the issue. Why this issue is so 'hard to find'; copper wires would not wear out but last 'eternally', the$e markets would collapse:
"...The world ignition wiring sets market is forecast to rise to US$24.8 billion ..."
www.mindbranch.com/products/R241-7360.html - 21k
Heres couple of wire shops & NGK plug numbers for u to further googling:
http://www.magnecor.com/magnecor1/main.htm
http://www.heeters.com/sparkplugs.shtml
http://www.magnetoparts.com/cat_index.htm#Wire
NGK 5Kohm caps
LB05F (angle)
SB05E - 14mm thread, Phenolic resin £2.06 Each , about 3$
SB05F - 14mm thread £2.06 Each
SD05F - 10 & 12mm thread
http://www.spark-plugs.co.uk/graphic...caps/SB05E.jpg
With this price I'll come over and install a set for u , Range Rover -style:
http://www.roverconnection.com/Plaza/ultra.jpg
! Only 499$
Btw. I can sell cheaper...
Smbdy suggests:
Find and buy the Bosch plug wire kit for the old flat-four aircooled VW
Beetles. The coil ends are the correct sex, amd the wire is copper core.
Old Jul 27, 2005 | 09:39 AM
floods943's Avatar
Running rich? Black smoke?
Check your 02 sensor and/or TPS (throttle position) sensor. In fuel injected vehicles, these are the most common culprits for a bad air/fuel ratio.
You are probably also wasting $$$ with gas because of this problem. When I changed my 02 sensor, I jumped from like 215miles to 350 miles per tank city driving. It made a hell of a difference, and my car runs better.
Old Jul 27, 2005 | 09:42 AM
floods943's Avatar
Whoa, I guess I learn something new everyday.
My plug wires (which I paid $55 for) suck. period. Infact during the height of humidity here, it's not uncommon for one of the wires to just stop conducting, and my car runs on 5 cyl.. =(
Old Jul 27, 2005 | 09:55 AM
Mogium's Avatar
Sorry if it is off subject. but I am working ona 94 max and upon reading the haynes repair manual it seems to suggest there is no starter on 94's.. If this is true what replaces it. and if it isn't WHERE IS IT?
Old Jul 27, 2005 | 10:04 AM
Wiking's Avatar
Originally Posted by Mogium
Sorry if it...if it isn't WHERE IS IT?
lol. Best jonke since squirrels ate her ign wirings
Must be in -93 junk trunk?
Dont read that crap, you'll grow angry...
Old Jul 27, 2005 | 10:05 AM
Jeff92se's Avatar
I'm needing a caw
Um what do you think starts your car everytime you turn the key? Yes you have one. Just like the 89-93 maximas.
Old Jul 27, 2005 | 10:32 AM
Mogium's Avatar
Well where is it? The manual doesn't show or tell where it is
Old Jul 27, 2005 | 10:33 AM
Jeff92se's Avatar
I'm needing a caw
What year model is your car??
Old Jul 27, 2005 | 11:00 AM
Mogium's Avatar
it is a 94 maxima dunno the body style but it looks to be the base model has a v630e engine
Old Jul 27, 2005 | 11:03 AM
Jeff92se's Avatar
I'm needing a caw
I know it's a 94. Automatic?? GXE? SE? Do you mean VG30E?
Old Jul 27, 2005 | 11:25 AM
Mogium's Avatar
it is an automatic 94.. there is no chrome trim and cloth seats.. other then that I dunno. On the engine it says v6 3000 if that helps
Old Jul 27, 2005 | 11:31 AM
Wiking's Avatar
VG30E; just dive down left of batt... just the same as in VE30DE...
Chilton manual is confunzean; pls check Favorite Links at left http://www.cardomain.com/ride/748507/5
Old Jul 27, 2005 | 12:07 PM
Alex_V
if your looking in the engine bay, the VG has the in take running to the front, then does down in front of then engine and curves around to the MAF, the VEs intake goes off to the side directly into the maf.
~Alex
Old Jul 27, 2005 | 12:11 PM
Mogium's Avatar
it is a vg I check whre the picture shows the starter to be and all I see is this big black plasting cylinder shape thing.. itis about 5 inches by 8-10 inches in length
Old Jul 27, 2005 | 12:43 PM
Mogium's Avatar
alright now I found it.. thanks for the help guys. It was on the very bottom of the engine compartment next the the manifold
Old Jul 27, 2005 | 05:35 PM
if he works cheap enough, i might consider calling him that. HA AH just messing, thanks wiking
Old Jul 27, 2005 | 10:52 PM
Wiking's Avatar
The prblm is, I just keep surfin: outside hoho. =dunno what words 'work or hoho' mean. haha. No harm done, its easier not to understand...
Mogium: I bet u did not click on the Favorite Links on my web page.
Old Jul 28, 2005 | 09:37 AM
Mogium's Avatar
Sure I did. But the starter still wasn't where the pictures showed lol. I have alot of work to do on this car so I will be back to post more in a few days lol. among other things valve cover gaskets, a new front blinker,a full exhaust overhaul and a little bit of body work.
Old Jul 29, 2005 | 06:41 PM
TheGreat's Avatar
okay it runs rich I can smell it no black smoke but its just crazy because heres the story I changed my fuel injectors and put in a diffrent fuel rail well the fuel rail I put in was bent so it was letting air in causeing it to back fire so I took it all back apart took out the injectors and put them back into the original fuel rail and now this runs rich has no power but at idle it runs perfect and smooth almost like as soon as you touch the gas it just dumps it all in and I'm like wtf so now its parked so help is great and also some one suggested checking for codes well I tried that but it throws like three codes then it throws code 55 which is normal operation so what do I do
Old Jul 29, 2005 | 11:32 PM
Wiking's Avatar
...55 which is normal operation so what do I do
If we suppose injector issue is ok (quite an assumption), then
- fuel pressure.
- air leak
- Connectors, hoses open?
- Wires, plugs cap etc
- Voltage level at batt, ECU.
- TPS; only while cold. Measure, clean: http://www.cardomain.com/ride/748507/6
- MAF, sensor issues. Check: http://www.cardomain.com/ride/748507/9
Old Jul 29, 2005 | 11:48 PM
Wiking's Avatar
Sure I did. But the starter still wasn't where the pictures showed lol. ...
All gas engines need some device to start rotatin. Typically its done via a flywheel; on the edge there are gears where electric motor engages.
Flywheel is between tranny and engine, so our starter has to touch it some day. In maybe 99% cases, all gas engine cars, the starter is found on this 'faultline'.
Heres engine end - see the only (3) spot where starter could be installed - pic in the manual, crap chilton manual from free online www.autozone.com...
...or another pic from haynes/chilton, see near LH mount:
Old Jul 29, 2005 | 11:53 PM
Bill Brasky's Avatar
Seperated at Birth?
thats correct. you have to turn a crank in the front of the car behind the license plate. don't confuse it with the dipstick.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Pied
Sep 26, 2015 03:29 PM
