help with temp gauge
Old Jul 29, 2005 | 09:56 AM
max723's Avatar
installed my temp gauge today. i made a t fitting off the throttle body coolant line. when all said and done the gauge will only read up to 84 farenheit. one end of the sensor is threaded and the nut only goes down 2 threads so i just wrapped the wire around the sensor. i bleeded the air out and it still is only 84, what can i do?
Old Jul 29, 2005 | 10:06 AM
internetautomar's Avatar
mod or sell?
put the gauge in the head where it belongs?
Old Jul 29, 2005 | 10:08 AM
Wiking's Avatar
- Measure its resistance, compare, see http://www.cardomain.com/ride/748507/8
- If air bubbles in, drive one hour full heat on over 2000rpm; loosen ahose to cause a tiny leak (air will find its way out). Very tiny leak, keep coolant level up.
Old Jul 29, 2005 | 11:04 AM
max723's Avatar
ok, ill try that. i put it in a cup of boiling water and no good-still 84. summit is sending me a new sensor to.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
RWCreative
Sep 21, 2015 11:01 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
asianstyle
Sep 10, 2015 11:30 AM
