injectors and premium fuel
Old 07-29-2005 | 12:26 PM
tripleGmax's Avatar
Ok, so i got my radiator flushed today and there is a new guy that works at the shop i always take my car. he suggested that i run premium fuel everyonce in awhile to keep my injectors clean......
any truth in this? because the one time i ran premium my car didnt run that great it seemed...i have no advanced timing or anything.
just curious
Old 07-29-2005 | 12:33 PM
lophix's Avatar
that's like saying regular fuel is dirtier than premium...
Old 07-29-2005 | 12:38 PM
Jeff92se's Avatar
I'm needing a caw
It's the wheels.
Premium is supposed to have more detergents to keep existing clean injectors clean. But by no means will it actually clean out a dirty injector.
I'd would just buy a bottle of Techron and put it in once every few months?
Old 07-29-2005 | 12:56 PM
ghettoshark's Avatar
Or just use Chevron gasoline. It has Techron in it which Jeff92se said is good. All grades of it have it, even regular! Wait, I'm starting to sound like i work for Chevron.
Old 07-29-2005 | 02:17 PM
tripleGmax's Avatar
there are very few chevrons around these here parts...
ok thanks jeffy....the guy who always works on my car hasnt seen it since it was stock ride height and stock rims...he was like "what the hell you do to your car? it went from grocery getter to giterdone" i bout lost it
Old 07-29-2005 | 02:28 PM
avmaldo's Avatar
If you want to clean your injectors try lucas injector cleaner. That stuff works pretty well.
Old 07-31-2005 | 03:57 PM
Will's Avatar
Hard to say. I have bad fuel injectors, and when the motor started shuddering, I changed to premium full-time (before, I would only use it occasionally), and dump in either Royal Purple or Slick50 fuel system cleaner (depends on whatever is in stock) every 3000 mi or every oil change. Since then, the car runs normal like it used to.
Old 07-31-2005 | 04:08 PM
mattcomet82's Avatar
slick50 comes from beyond the gates of hades...
Old 07-31-2005 | 04:10 PM
Will's Avatar
Feel free to elaborate. I haven't had a problem as yet using it.
Old 07-31-2005 | 07:41 PM
falseicon's Avatar
Just an fyi. Chevron Techron is offering full rebates on up to two 12 gallon treatment bottles till' the end of the month (I found the mail-in at Autozone). Free stuff is always nice, especially when it's the stuff you use.
Old 07-31-2005 | 09:33 PM
Cliff Clavin's Avatar
Way out West
I thought Nissan recommended against using any kind of fuel injector cleaner?
If you are going to use it, I believe most shops and dealerships use BG 44k and there are a lot of guys in the fluids and lubrications section that claim to have good results.
Old 07-31-2005 | 10:18 PM
maximagxe90's Avatar
it is true,
nissan says not to use fuel injector cleaner,
because it will distory the inside of the injector,
i lost a fuel injector because of using chevron techron,
i tried lucas fuel injector cleaner and it didn't help that much either
Old 08-01-2005 | 06:35 AM
Will's Avatar
It's true. Out of desperation, I've been occasionally using some, but so far so good, and I'm stickin' to it until they die.
Old 08-01-2005 | 08:28 AM
tripleGmax's Avatar
what is it that kills them?
Old 08-01-2005 | 08:45 AM
Will's Avatar
There may be more reasons, but basically because these additives are strong solvents, it can eat away at the injector seals and screw the injector up.
Old 08-01-2005 | 09:06 AM
eric93SE's Avatar
the solenoid in the injector runs in the gas, so the solvents eat away at the windings, eventually shorting it out.
Old 08-01-2005 | 09:08 AM
tripleGmax's Avatar
but BG 44k is safe?? what is the "solvent" that actually kills the injector
Old 08-01-2005 | 10:01 AM
eric93SE's Avatar
Its probably not safe.
Old 08-01-2005 | 12:41 PM
Way out West
From what I understand, no solvent (cleaner) is totally safe. I I think the BG 44K is used because it is strong and works well. It actually cleans a lot of the crap out. It might also do a bit more "eating away" of parts in there, too.
I think if you were to use injector cleaner once in a very great while, it isn't going to destroy your injectors. It likely will if you use it every month or every oil change or some other frequent application.
I am no professional, so please don't take this as advice, just my own opinion.
Old 08-01-2005 | 12:48 PM
tripleGmax's Avatar
i took your professional advice Red92MaxSE and now my car has all bad injectors and im holding your responsible.........ok ok im kidding, but i get what youre saying now, thanks a bunch man!!
i usually only run something through once every 3 months, but i had been putting alot of miles on my car....
Old 08-01-2005 | 01:17 PM
greggie195's Avatar
with my old nissan I used to use Marvel Mystery oil at every oil change, in the fuel and in the engine. Kept my car going to 225,000 miles with never doing any engine work (just tune ups and the like) I finally got rid of that car because coolant was leaking into the passenger side and the car was falling apart, but the engine was as solid as ever. I now sometimes use MMO but it has gotten ridiculously expensive, so its a rare treat for my Maxima.
Old 08-01-2005 | 01:19 PM
Jeff92se's Avatar
I'm needing a caw
I poured in like 6 gallons of injector cleaner before I gave the car back Chris.
Old 08-01-2005 | 01:43 PM
Way out West
hmmm, maybe that has something to do with my VTCs ticking on a motor that looked so clean.
Old 08-01-2005 | 01:46 PM
Jeff92se's Avatar
I'm needing a caw
You know what? My engine is just as clean. But it starting ticking away recently too. It might be the fast idle + hot weather + 5w30 oil. I notice when it's a bit colder out, it won't tick nearly as much. I might try short changing the oil with 10w 30 and see what happens. I also note that the tick reduces alot with the new filter. One option might be to 2x the filter changes and maybe use synthetic. Dunno.
Old 08-01-2005 | 09:32 PM
i have only had experience with their oil additive. i knew a couple of guys that, when changing oil after a few treatments, their lubricant began to coagulate. no doubt gumming up under higher temps. granted these were more intense 4wd applications, but still cause enough not to trust it in your engine. lucasoil additive is proven safe 100% petroleum that bonds well to valtrain parts greatly reducing dry startups and valve chatter. but you guys don't care about that cause this is a fuel additive thread...
Old 08-02-2005 | 05:50 AM
eric93SE's Avatar
Orrrrr, rebuild the VTC's
you could try a motor flush at your next oil change (use a cheapo filter while doing the flush). that will help clean the oil gallies.
Old 08-02-2005 | 06:32 AM
mtcookson's Avatar
i do believe all grades of gas are required to have detergents. no one grade is cleaner than the other. the only time you need to run premium is if you start hearing pinging/knocking/detonation on lower grades of gas (i.e. if you're making quite a bit more power over stock that requires you to use gas that resists pre-detonation better).
Old 08-02-2005 | 06:40 AM
internetautomar's Avatar
mod or sell?
or you're running a VE with the knock sensor bypassed
Old 08-02-2005 | 07:13 AM
tripleGmax's Avatar
Originally Posted by greggie195
...I now sometimes use MMO but it has gotten ridiculously expensive, so its a rare treat for my Maxima.
uhhhh its like 3 dollars for a small bottle(can be used twice on our tanks), thats expensive??? lol
Old 08-02-2005 | 08:02 AM
Way out West
I have a set of rebuilt VTCs sitting in my garage. No way am I going to install them after all the crap I went through last time. That's why I have a JDM engine in there now.
I might do an engine flush later in the summer.
I changed the oil when I got the car back from Jeff (September or October?) and I changed it again like in March. I think I have driven it maybe 600 miles since March and maybe 900 miles since Jeff installed the JDM.
Since I don't drive the Maxima much, I usually just change the oil every six months or whenever I get bored enough to do it.
Old 08-02-2005 | 08:10 AM
Jeff92se's Avatar
I'm needing a caw
That's the thing. My engine is squeaky clean. Absolutely no varnish at all. Looks like Chris's jdm engine. I don't see how the gallies could be clogged at all. Perplexing.
Old 08-02-2005 | 08:11 AM
Jeff92se's Avatar
I'm needing a caw
Don't be a wuss.
Old 08-02-2005 | 08:13 AM
Maxima Man's Avatar
Sorry but what is MMO that cost 3 dollars a bottle?
Just a question what type of oil do you guys use in your maxs
( the name brand and viscosity )
Old 08-02-2005 | 08:35 AM
eric93SE's Avatar
Don't be a wuss.
I know, after you do the job once its a peace of cake the second time around.
MMO= marvel mystery oil (essentially snake oil in a can, people sware by it).
Old 08-02-2005 | 08:37 AM
Jeff92se's Avatar
I'm needing a caw
How long as your rebuild lasted? The 1st time I let the dealer do it, one ticked after about 10,000 miles. I'm not that sold on rebuilt vtcs
Old 08-02-2005 | 08:47 AM
tripleGmax's Avatar
my vtcs havent started clacking yet......cross my fingers!!!
Old 08-02-2005 | 11:52 AM
Way out West
Well, I drive my car between 1500 and 2000 miles a year.
I think even if they were clacking almost full time (they only clack sometimes right now), I should be able to squeeze 10k miles (about 5 years for me, give or take) out of the car. That's good enough. Maybe in 5 years I will consider putting in the rebuilt ones.
Old 08-02-2005 | 11:54 AM
tripleGmax's Avatar
wow, i used to do that in 2 weeks driving!!! but i just moved.
Old 08-02-2005 | 11:58 AM
eric93SE's Avatar
Its only been 6k, I'm not commuting like I used to . I wanted to add a counter on my sig, but the number won't move much . I have a little tick during startup but thats just the lifters and its only 2 seconds, and probably due to the car ocasionally sitting as much as 24 hrs.
Old 08-02-2005 | 12:00 PM
eric93SE's Avatar
I agree, I don't think premium has anything more in it. It just burns cleaner and releases more power due to the higher octane rating (the others have hexane I believe) .
Quick Reply: injectors and premium fuel
