is this normal?
Old Aug 2, 2005 | 05:06 AM
max723's Avatar
is this normal?
i checked the bottom of my tranny today and it looks like there is a leak. it is moist and looks as if there is a leak but nothing drips or leaks from my car.
Old Aug 2, 2005 | 05:49 AM
Greeny's Avatar
¯\(°_o)/¯
Any leak is not normal....
Your problem may be the rear oil on the engine leaking, driveshaft seals or front tranny seal..
Old Aug 2, 2005 | 06:00 AM
eric93SE's Avatar
yeah, if its on the tranny casing itself, then its probably the rear main seal. don't worry about it if its not dripping. to fix it, you need to drop the tranny
Old Aug 2, 2005 | 06:02 AM
max723's Avatar
so get it changed if i ever replace the clutch? also what is that tube going from my tranny to near the intake but isnt connected to anything.
Old Aug 2, 2005 | 06:32 AM
Greeny's Avatar
¯\(°_o)/¯
As you drive your car and heat builds up in the tranny, the gear oil will release gases..Them gases need to be vented out...
That is the purpose of the hose....to vent the gases.
Old Aug 2, 2005 | 09:59 AM
Wiking's Avatar
Originally Posted by MyGreenMax94
As you drive your car and heat builds up ... purpose of the hose....to vent ...
To be exact, its heat expansion tube. World is full of this breathing: any closed container is either gettin warmer - or cooling, compared to surrounding ambient temp. This causes pressure disparity.
Higher pressure always wants to flow to lower pressure, like electricity, or water. If there was no outlet in a tranny, this flow would happen via axle seals. That would also cause oil leak, which nobody likes...
Now any closed container is in this breathing business: this is why dust creeps into places like camera lenses, electronics boxes etc. During years these will malfunction because of the dirt or moist carried by this breathing. Well sealed metallic containers fight this phenomena best, but in our tranny we cannot seal up all: we need axles (=seals) to let our horses walk, even race.
Old Aug 2, 2005 | 12:30 PM
max723's Avatar
ok thanks. .
Old Aug 2, 2005 | 01:55 PM
eric93SE's Avatar
yes
10char
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
RWCreative
Sep 21, 2015 11:01 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
