Can you guys help me with this error #32
Old Aug 8, 2005 | 08:42 AM
MAXI's Avatar
This is a recurring prblm for me. Error #32-EGR...how do we fix this????
thank you much for your inputs.
Old Aug 8, 2005 | 09:55 AM
lanedrifters's Avatar
first,check your vacuum hose condition and route. you probably have a vac. diagram on the underside of your hood. then check to see if your EGR holds vac.(pull of the hose , lift up on the diaphragm and put your finger over the vac port, the diaphragm should stay up.) If it does then find the egr temp sensor and pull it off and clean any carbon buildup with carb cleaner or a scothbrite pad/light sandpaper. if you still have problems youll have to check the vac solenoid for egr and maybe even pull the egrvalve off and clean carbon from it too.
mvm062
Nov 30, 2020 09:00 AM
Starrider
Dec 18, 2015 04:43 AM
I<3 A32's
Sep 10, 2015 11:07 AM
nbstriker10
Sep 4, 2015 04:26 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
