1st Axle Replacement - Front driver's side
Old Aug 12, 2005 | 05:12 AM
Pauls 98 SE's Avatar
I have been looking for a write up on the axle replacement and do not see one, so thought I would ask about the procedure. Have previously removed a hub to have new bearing pressed in, so familiar with the disassembly. Is their anything special I need to know about removing the axle? Once hub is out of way, just slide axle out? Thought I rememberred someone's posting to be careful about a seal when sliding in new axle.
Thanks again for the help!!!
Old Aug 12, 2005 | 05:27 AM
DanNY's Avatar
Ad·min·is·tra·tor
yes becareful of the seal...replace it if it's old. remember to drain the tranny fluid before you pull the axle...then after that you just pull on it hard and it'll come out.
Old Aug 12, 2005 | 11:43 AM
Red89maxima's Avatar
It's really easy just disconnect your lower control arm from the knuckle and take off your axle nut, then you can just push your strut/knuckle assy out of the way and pull the axle out. It's a little eaisier with two people for this process (friend can hold the strut/knuckle assy out of the way). And always check the seal! you'll kick yourself if you don't and it leaks in a week or two!
Old Aug 12, 2005 | 11:57 AM
Jeff92se's Avatar
I'm needing a caw
I don't have to do that to get the axle off.
Old Aug 12, 2005 | 12:09 PM
??????What do you do?
Old Aug 12, 2005 | 12:38 PM
Jeff92se's Avatar
I'm needing a caw
Two strut mount bolts. A bit easier. I hate the 3 lower control arm bolts. Actually I'm not sure I even have to do that. I was doing the bbk and konis in that picture.
Old Aug 12, 2005 | 12:44 PM
Yeah I guess that'll work better. I was just thinking what I did when I swaped trannys, and had to take out axles
Old Aug 12, 2005 | 03:30 PM
DanNY's Avatar
Ad·min·is·tra·tor
i can't do the strut thing since i have camber bolts and i don't feel like getting another alignment. i just took off the 3 nuts at the ball joint..then it's was smooth as butter from there.
Old Aug 13, 2005 | 08:49 PM
falseicon's Avatar
The Autozone site listed through the stickies has a decent write-up.
I just changed out both sides two weeks ago and it went fairly well; I did have to use one huge crow-bar dropped down from the top, PB Blaster, a chisel and some nasty words when doing the pass. side as the support bearing and bracket had bonded to the cv shaft. If you have an automatic I'm pretty sure you need to pull out the pass. side to get out the drivers side, but one of these guys would know better than I.
Old Aug 13, 2005 | 08:58 PM
nope you can do the drivers side by it's self without taking out the passenger side
Old Aug 15, 2005 | 01:08 AM
seanneal's Avatar
Plus, if you do the driver's side first (easier to get a prybar inbetween to pop it out), you can do this trick to get the passenger side axle out:
Old Aug 15, 2005 | 01:24 PM
Phatsta's Avatar
I have a guide to replacing the axles but my cardomain site has lost all pictures... don't know what's wrong with it. so it's useless.
Old Sep 6, 2005 | 03:25 PM
meanis's Avatar
I was going to try this today. I have the drive shafts, but having problems locating the seals. First i can't find what trasnmission i have other than it being a 4 speed auto, autozone wants to know if it RL4F03V, RE4F04A, or RE4F04V all of which have differant seals. The manual i have in fornt of me states that the 90 came with a RE4F02A, which as you can see is not on there list of tranny's. As far as trying to id the tanny the only number i can find is A706197 which is on top of the upper oil pan. Any help would be great
Old Sep 6, 2005 | 03:44 PM
MyBlue92Maxima's Avatar
you have any write up on just putting a boot over the C.V. joint , i plan on putting it on friday if you could get one by then for me :O
Old Sep 6, 2005 | 08:32 PM
falseicon's Avatar
here is a write-up on doing the cv boots
http://www.4dsc.com/articles/drivetr...cv_boots.shtml
or go through auto-zone site (check the stickies to see how)
I'm told it can be done w/o taking the whole shaft out, or with those 'zip-up' boots but I'd never try it. If your boots already torn your better off doing the whole thing.
as for the seals, we have the exact same car and I didn't need to supply that info to get those parts. Tell the folks behind the counter you want the seal where the CV and trans meet, they might be looking at wheel/axle seals or who knows what else. I don't have the invoice handy, but if i find it tomorrow I'll drop you a line with the 2 numbers (right and left). Hope you're ready for a fun time with the support bearing bracket on the pass. side, mine was not exactly fun.
kingw323
20
Oct 21, 2015 08:36 AM
Samedi
Aug 12, 2015 01:54 AM
erniel
Aug 8, 2015 09:32 AM
ZerotoSixty
Aug 6, 2015 04:34 AM
dauntlessmax
Aug 5, 2015 10:29 AM
