Shifting at high RPM
Old Aug 16, 2005 | 05:34 PM
MAXI's Avatar
What kind of problem would cause an AT to shift at 4500 to 5000+ rpm?
BTW, its got fluid - i just checked them.
thanks
Old Aug 16, 2005 | 05:45 PM
Supercross's Avatar
Do you have the A/T Switch set to Power? On the "Power" setting it revs much higher than usual.
Old Aug 17, 2005 | 01:29 AM
Wiking's Avatar
Originally Posted by MAXI
...got fluid - i just checked them.
thanks
Define:
- speed?
- gear?
- up -or- downshift?
First thing to check: what is your charge voltage when u have that problem?
Old Aug 17, 2005 | 08:25 AM
Alex_V
You dont want to shift at high rpm?
~Alex
Old Aug 17, 2005 | 12:44 PM
MAXI's Avatar
i think i have to make this a bit clearly.
tranny seems hesitating to upshift between 3rd and 4th...and if it does, rpm is usually around 4500 to 5k.
Old Aug 17, 2005 | 01:47 PM
MrSector9's Avatar
doe sit only do it between 3 and 4? any throttle setting? sounds like it could be a shift solenoid.
bryants95max
Oct 2, 2015 12:52 PM
carlosvq30
Sep 26, 2015 09:44 AM
dcardello
Sep 3, 2015 11:44 PM
