Non-Bose head unit installation
Old May 24, 2001 | 03:54 PM
Shep's Avatar
I wired up my harness to my aftermarket head unit, and put installed it in my 93 Maxima. When I plugged in the harness into the head unit, the power antenna went up, but the unit won't turn on. I checked the harness and I wired it up properly, but I noticed that there are a few wires that come out of the factory side of the harness at different spots than the one I bought. Does anyone have the wiring codes for the non-bose (clarion) system? I can't figure it out!
Old May 24, 2001 | 08:45 PM
Matt93SE's Avatar
STFU n00b!
check the wiring info.zip file on my faq page.. it might be in there.
http://www.ee.utulsa.edu/~mblehm/faq/
also look at the rear amp bypass.txt file. if you install an aftermarket head unit in your car, you'll need that info too.
Also, check the ground connection on the wiring harness.. if you used an adaptor harness kit, the ground is non-existant on the car side of the harness.. you need to run a seperate ground for the new head unit.
hope that helps. good luck.
Old May 24, 2001 | 09:57 PM
93 SE's Avatar
is your antenna connected,did you have to get an adaptor...i had bose,but my symptoms were same as yours
Old May 25, 2001 | 08:49 AM
Shep's Avatar
I haven't gotten the adapter yet, but I just assumed that the cd player would work without the antenna attatched.
Old May 25, 2001 | 11:05 AM
93 SE's Avatar
theres your answer,i didint get the adaptor cuz i figured i would just listen to cds first ,when i got the adaptor everything fell into place and worked ,its $10 at circut city...you need it
Old May 25, 2001 | 05:57 PM
Shep's Avatar
I just picked up the adapter, I'll put it in tomorrow evening and let you know if it worked... hopefully it does!
Old May 27, 2001 | 10:48 AM
Shep's Avatar
Well, I installed it, and it works. Only problem is, the rear speakers don't work! Do I need to bypass an amp back there? I've got the non-bose system, so not many people know what to do.
Old May 27, 2001 | 04:57 PM
blackonblack
Check out
http://www.installdr.com - They have the most accurate diagram for non bose systems
Black Max
Old May 27, 2001 | 07:28 PM
Shep's Avatar
Well, got it all to work, I just had to rewire the rear harness so it bypassed the amp. Thanks for the help
MaxLife17
Jun 27, 2019 01:37 PM
melteye
May 16, 2016 12:02 AM
cruce91
Sep 20, 2015 10:23 AM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
