VTC's and oil type
VTC's and oil type
Recently someone wrote that for noisy vtc's they use not only the Toyota filter but also they use 10W40 Castrol GTX instead of the 5W30. I had not heard that before. Any of you old timers back that up? What does that do to gas mileage? Any reason not to do that?
I have tried a heavier weight oil[20w50] to quiet mine down With no luck. My gas mileage did suffer as a result...
so i just went back to castrol 5w30 synthetic blend..and keep the radio turned up..
![Rotz](https://maxima.org/forums/images/smilies/rotz.gif)
a 10w* motor oil may keep them quieter on startup because it's thicker, but that's only once the oil gets up there.
the whole point of using the 'yota filter is that it's supposed to have an anti-bleedback valve (like Wix does) to keep some pressure already built up in the system.
that's the theory behind it at least
Originally Posted by kiyakerz
not sure, but everytime i bring my car in to get hte oil changed, the guy at the counter stares at me like i'm insane because I'm holding a toyota filter. ![laugh](https://maxima.org/forums/images/smilies/laugh.gif)
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Originally Posted by Aaron92SE
Learn how to change your own oil. ![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
But, with the prices of oil, you only pay like 5 bucks more to have someone else do it and dispose of the oil and ish. Pretty good deal, $12 oil changes are almost cheaper than a standard filter $4 and oil $7.
I still would never pay someone to do something I am fully capable of. Its an expression of my manliness
![smash](https://maxima.org/forums/images/smilies/smash.gif)
BTW I use(d) 10W40 in both maximas, but I'm in AZ where temps rarely drop below freezing and are consistantly 90s+
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
If your VTCs are already noisey, no combination of oil and filter is going to quiet them down (for long). I grounded my VTCs and did not notice a difference in performance on my old beater. The VTCs have been quiet ever since, however.
![Butt Shex](https://maxima.org/forums/images/smilies/gaysex.gif)
As far as the grounding thing, I grounded mine since they were noisy, then i was having weird idle problems so i tried ungrounding it (just incase/simple to remove) and for some reason they were quiet... I am not complaining thoguh,tomorw they will be noisy now :P
I used a Wix filter last time i changed
Originally Posted by thajones
^^^ now that's what I was wondering. Someone in another thread said I WOULD notice the difference in power.
It is rather embarassing to start your car up in a parking lot and it sounds like who-dun-it-and-why
They advance the timing so that you can have lots of torque and then the horsepower numbers...So ina way they aid in the lower end since they can set the timing so you get the big torque output.
If it wasnt for the vtcs you would have to pick if you wated the big torque or the higher horsepower rating.
BJ White
BJ White
Originally Posted by MrSector9
12 hp loss over noisy vtcs? or 12 hp loss over fully functional non noisy vtcs.
BJ White
BJ White
But VTCs were designed to give the VE some extra low end power. When you press the gas, they should be engaged. When you reach a certain rpm, they turn off and you experience the normal top end power that you would have had if the VTCs were never created. But, when you ground the VTCs, the cam advances and you only get normal low end power and the VTCs never release at that certain rpm and you experience a loss in top end power.
So, BJ, you explained it correctly. I just wanted to clear it up a little bit.
haha I can understand it in my head but i am a horrible teacher ![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
Well I was wondering about the noisy VTC thing since I kwno they grow noisy due to weak springs so I thoguht that might have affected their ability to retain the spring set position.
I just registered to this forum and EVERYONE seems knolegable about the maximas....im a new maxima owner and i love it
i have the 1993 5-spd SE VE30DE engine and I DO have the VTC noise...and im REALLY looking to fixing it myself but...it says its not meant for a beginner...."if you can do a 5 spd trnny swap you can do this" but the only real hardcore thing ive done to a car was switch out a clutch my friend burned lol anyways im deffinatley learning more about the stupid VTC's noise and im really looking to get it fixed in stead of hiding it....then switching to the synthetic oil and toyota filter.
![Woo woo](https://maxima.org/forums/images/smilies/woowoo.gif)
I use Castrol Synthetic blend 10w40..The oil filter I have been using for some time now is the blue Purolator one..Not the cheap white one...I only get the ticking like once in while, but most of the time, no noise...**Knock on wood**
from my short expierence with the vtcs i found that the yota filter and mobil 1 full synthetic worked good to hush them for a little bit but it would always lurk back in about 500 miles as far as grouding them i did it for about a day and hated that fact that i was losing power and i could definatley feel it big time up top
i think the only way to solve the problem is to rebuild them or get new ones the process is straight forward and can be done in an afternoon im so happy i put in new ones ive driven the car about 5000 miles since and havent herd a thing
kiyakerz u need to learn to change ur oil ive herd of some pretty messed up story from those lube places.....draining the trannyfluid and sending a car down the road with 8 quarts in the engine i dont trust anyone with my car
yep 200 bucks for brand new vtcs not the rebuild kit i stumbled upon a nice deal but yeah i think (not sure) but if you were to rebuild them yourself and do all the work it would be under 200 bucks its just the fact that most people dont want to play with the insides of there engine and its kinda time consuming i think i could do it now in under 2 hours with an extra hand
Originally Posted by PunkFriday
everytime i get that filter, it just looks... small. maybe i am getting the wrong one. for a 1998 corolla, right? man, i'd feel dumb if i screwed this up.
the clacking stopped when you put the new filter on?....cuz i herd if you have the clacking you cant make it stop...unless you fix it then you put the filter on and you can prevent it from happening again
the clacking stopped when you put the new filter on?....cuz i herd if you have the clacking you cant make it stop...unless you fix it then you put the filter on and you can prevent it from happening again ![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
06-06-2017 02:01 PM
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
