Tach is possessed!!!
Old Aug 20, 2005 | 08:13 PM
CyMax's Avatar
I don't know what to say other than my tach reads exactly what IT WANTS to!!! It seems to be worse when the car is cold but it will still jump to a higher RPM seemingly whenever the fancy hits. Oh the only other bit of info I can think of... when it freaks, it's always to a higher RPM. I'm going to check out the level and make sure its correct tommrow, but if anyone has an idea HELP!!!!!!
Old Aug 21, 2005 | 07:02 AM
OBEEWON's Avatar
Does your engine jump to higher rpms too or just the tach? I know if you have indiglow gauges the face for the tach tends to puff up and hinder the needle from moving freely. this may or may not help, but I tried.
Old Aug 21, 2005 | 09:00 AM
CyMax's Avatar
Nope engine speed dosent change just the tach. Thanks tho
Old Aug 21, 2005 | 10:24 AM
Wiking's Avatar
Originally Posted by CyMax
...my tach reads exactly what IT WANTS to!!! ...
Cannot believe... more likely its doing what its told to do. Some where there is a short circuit injecting electrons by bucketfull. Each bucket gets u poor tacho shivering...
- test the sensor input
---ECU pin 53: 0V -or- 7-9V while ign on, engine stopped, front wheel is rotated
---Speed sensor connector pins a/b: merry go around on/off as front wheel is rotated
- Take out u instrument assy and try to find the reason for short. If u cannot find out, install a analog voltage gauge to the wirings coming from the sensor; if no problems there, the short circuit is in the i-assy.
try diggin more from here ...............↓↓↓
Old Aug 21, 2005 | 09:14 PM
Jeff583's Avatar
i have the exact same problem and i know its not the guage or guage cluster in mine.
Old Aug 21, 2005 | 09:23 PM
CyMax's Avatar
Good to know I'm not seeing things!!!
Old Aug 22, 2005 | 03:19 AM
Hectic's Avatar
ground check. you also might want to grind your starter.. this caused and fixed an inaccurate temp guage problem in 93 escort of mine. weird stuff.
Old Aug 22, 2005 | 12:36 PM
CyMax's Avatar
Do you mean ground my starter???
Old Aug 22, 2005 | 01:19 PM
Jeff583's Avatar
He means grind it as in try to start while running. I also think he is high. lol
Old Aug 22, 2005 | 02:07 PM
OBEEWON's Avatar
Also the solder points sometimes get loose on the pod. If you dont feel like messing with that buy a used cluster from a junk yard and change the tack only. I had something similar to this in my speedo, i tested everything and it seemed ok, but i changed it just to be sure. lo and behold problem gone.
Maxima Pride '07
Sep 12, 2015 07:29 AM
maximaham
Aug 7, 2015 01:11 PM
jetmax
May 1, 2001 12:18 AM
black96se
Jan 20, 2001 06:50 PM
