Oil Leak that Opec would hate!
Hey guys..been a while since I posted but I noticed that my litle oil leak has become a huge one! It is leaking out from the passenger side towards the front. I am sure this is a common leak so any hints or shortcuts would be appreciated.
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
Originally Posted by Governor
...so any hints or shortcuts would be appreciated. ![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
- seems like premature belt change time. Manuals do cover tHat pretty well. (But buy the seal from stealership.)
support internetautomart...He has got them...http://www.internetautomart.com/maxi...n/gaskets.htm?
but if it's only the seal he needs, he'd be better off at the dealer after shipping.
if it's part of a more major job (I.E. Timing belt) then get it from me.
Originally Posted by Harvs94max
crank seal as alex stated 7 bucks from the dealership and about hours work with the right tools
Make sure its the main seal, oil should be dripping from behind timing belt cover around the area of the crank pulley. If so...sounds like wiking is right, you should probably change the timing belt as well. You will have the thing off already and besides, leaky oil in the timing belt area has surely gotten on the belt. I think oil eats away at those belts.
Originally Posted by garbury
... Another reason why VE is king of the 3rd gens...
What u havent got, cannot break. If VG 5year tuneup is made as recommended, never there is a need to repair that seal.
Btw. Depending on miles, I'd also now swap the cheap VG waterpump, so no need for a revisit there during next 5yrs... No need to repair VTC, this time. But if tuneup is a worry, 2cyl 2-stroke Traband is the winner. Beetle comes abreast with its 45sec engine swap world record...
Originally Posted by MrSector9
I have aleaky main seal too... but i am putting up wiht it for now sicne i am stashing away money for a shiny new UDP... no point in taking that heavy old thing off then putting it right back on ![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
An hour would be good!!!
Last May I replaced leaking camshaft seals, because it would damage the belt, and the dealer told me the main seal repair would cost $1,000 because of all the stuff that had to be removed.
I've just been pouring the oil in, and felt like a rolling biohazard. <g>
What book would give the procedure?
Regards - Miles Thompson
Originally Posted by maxatlantic
...felt like a rolling biohazard. ...
Check Favorite links at left side http://www.cardomain.com/ride/748507/1
internetautomar : the VG actually has more parts
- Once in a lifetime, give the exact numbers... Belts/chains, valves, coilpacks, VTC's whatever.
VE $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ $$$
VG $$$$$$$$$$$$$$$$$
An hour's work?
Wiking- my VE has needed injectors (VG would too) window regulators (VG would too) Exhaust (VG would too) and I haven't needed to replace a cap (no gots) Rotor (no gots) or wires (no gots those either) timing belt (not one of those either) My VTCs work fine too.
so a VG is a more expensive maintenance vehicle than a VE more parts that need to be replaced on a REGULAR basis.
Pls do not start poems again... VE/VG classification falls strictly on engine. VG/VE full repair in the end, maybe ? 300k; Stricly exact facts...can u ever? Belts/chains, valves, coilpacks, VTC's whatever:
END of issue.
END of issue.
1. the chains should NEVER need to be replaced in theory.
2. VTC failure only occurs on a small fraction of the total VEs produced.
3. Coil packs go bad rarely, it's not a normal maintenance item. mine are still original and they are the oldest ones here.
litch
123
01-04-2024 07:01 PM
TKHanson
11-24-2018 01:39 AM
06-06-2017 02:01 PM
