Odd Hesitation
Old Aug 28, 2005 | 12:08 AM
emeraldmax's Avatar
Odd Hesitation
Hi everyone, I have a 1993 maxima GXE. Today i was driving, i was going about 65-75 mph and my car started hesitating really bad. Sometimes i would lose all throttle response. It acted just as if i ran out of gas, but i filled up on gas yesterday. I think it is most likely either the fuel pump or the ignition coil.
I'm leaning more towards the ignition coil because the fuel pump is only a few months old(it's a walboro 255lph). Anyone else have any suggestions or ideas? Has anyone experienced this before? Any help would be greatly appreciated. TIA
Sammy
Old Aug 28, 2005 | 01:56 AM
Wiking's Avatar
Originally Posted by emeraldmax
Hi...Has anyone experienced this before? ...
Yes and then some! Check pages relating u problem at http://www.cardomain.com/ride/748507/1
If no distr cap/wire/rotor/plug maint larely, swap now. Btw. 'New' pump dies as well as the ol workin...
Old Aug 29, 2005 | 02:46 PM
Will's Avatar
Yes, I had this problem, and it was my ignition coil that had a crap-load of aqua-coloured corrosion built up on it. Check under the wire boot that goes into the coil to make sure it's clean inside.
Old Aug 29, 2005 | 05:01 PM
Minty91GXE's Avatar
try misting the wires too - look for arcing
Old Sep 1, 2005 | 05:43 PM
tijkane's Avatar
Ignition coil at %90.00!!!
Old Sep 2, 2005 | 05:25 AM
internetautomar's Avatar
mod or sell?
huh ?
Old Sep 2, 2005 | 06:11 AM
tijkane's Avatar
You should check the coils. I had the same problem. It was the coils.
Old Sep 3, 2005 | 12:46 AM
shaun's Avatar
happend to me
turned out to be o2 sensor
Old Sep 3, 2005 | 01:26 AM
Wiking's Avatar
Originally Posted by red-line-racer
but can the coil die at any moment ...
- nobody can say if u have same prob: Symptoms might be like the same...
- death comes like that, any moment: for most, no preparation or warning. Better be prepared.
- read the info that has been offered above; check it out. Coil dies once in 100million miles. How many have u collected?
Old Sep 3, 2005 | 07:04 PM
mod or sell?
Coils get killed by heat, if you live in a mostly cold climate, the coil will last a very long time.
if you live in a hot/ humid climate then it probably won't make it much past 100k if even that
Old Sep 3, 2005 | 07:28 PM
Greeny's Avatar
¯\(°_o)/¯
That probably goes for most electronic parts on cars today....
05RLS2
Sep 27, 2015 09:24 PM
foodmanry
Sep 24, 2015 12:02 PM
JoshG
51
Sep 21, 2015 10:41 PM
jchronis2552
Sep 21, 2015 05:52 AM
trungg86
Sep 4, 2015 04:58 AM
