Intake Manifold Bolt Question
Old Sep 2, 2005 | 10:06 AM
hotrod37's Avatar
I have done a lot of reading and I still cant find the answer to my question. Maybe someone here who has replaced their manifold or injectors may know the answer to this question.
I have a 1992 maxima that just had an injector go bad. My upper manifold is secured with Torx bolts. I tried a T-40 but it seems to be a lose fit. I don't have a t-45 so im not sure of the exact size Torx I need. Can anyone tell me what size Torx I need.
Carl.
Old Sep 2, 2005 | 10:13 AM
Mizeree_X's Avatar
Getting back to his roots
Carl.
They aren't Torx heads, they are Hex (Allen) heads. I think they are 6 or 7mm.
Old Sep 2, 2005 | 10:15 AM
Greeny's Avatar
¯\(°_o)/¯
My 92 and 94 ve intake manifold bolts are 6mm hex bolts...not torx
Old Sep 2, 2005 | 10:23 AM
hotrod37's Avatar
thanks guys
Old Sep 2, 2005 | 12:09 PM
Greeny's Avatar
¯\(°_o)/¯
I also suggest buying the hex [allen] tools in the form of a socket...The intake manifold bolts are extremely tight in some cases...So you need to be able to get a lot of torque on then to loosen'um up .......
Old Sep 2, 2005 | 12:48 PM
Greeny's Avatar
¯\(°_o)/¯
Like these......
You can get these in them hard to reach places...
Old Sep 2, 2005 | 08:46 PM
CyMax's Avatar
Yep yep. I have found that having the same "tool" in various forms is never a bad idea, and will ALWAYS make you glad you did.
Old Sep 2, 2005 | 08:47 PM
CyMax's Avatar
Yep yep. I have found that having the same "tool" in various forms is never a bad idea, and will ALWAYS make you glad you have them.
Old Sep 2, 2005 | 10:52 PM
MyBlue92Maxima's Avatar
offhand question , the injector thats shot... is it the one in the top row in the middle? and yes , they are allen key holes i just went though the project about a week ago
Old Sep 3, 2005 | 08:17 AM
hotrod37's Avatar
no its the #1 cylinder
Old Sep 3, 2005 | 10:51 AM
used parts's Avatar
might want to tap the tool in with a small hammer, to make sure it's fully seated....that way less chance of stripping the inside of the bolt.
Old Sep 3, 2005 | 03:51 PM
Alex_V
Agreed. One of mine did that, but it was on the out side so I ground it off. But its is 6mm allen/hex head. I have 3 sockets and 1 screw driver so I cant loose it as most hardware stores close to me carry it off and on.
~Alex
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
