how can i tell if timeing belt snaped????
Old Sep 4, 2005 | 05:11 PM
red-line-racer's Avatar
hey can anyone tell me how can i tell if the timeing belt has snaped im trying to buy a non runing maxima but i want to know if its not the timeing belt that is broken.the guy told me he heard a bang under the hood while driveing could that be the timeing belt snaping???
Old Sep 4, 2005 | 05:53 PM
Greeny's Avatar
¯\(°_o)/¯
easiest way i know is to take the distributor cap off and bump the starter a little
If it moves its alright if it don't......well.....
Old Sep 4, 2005 | 07:25 PM
Harvs94max's Avatar
more than likely its the timing belt the bang was the valves nailing the pistons which means basically u need another motor u can find vgs for cheap so if the cars nice and ur some what of a home mechanic id go for it
Old Sep 4, 2005 | 08:30 PM
nismosleeper's Avatar
Yes the bang most definately was a valve or two getting some hardcore action on with the piston. I don't think that it is worth it unless you can get the car for one fifty or less....that's a lot more than a salvage yard will give him.
Old Sep 4, 2005 | 08:54 PM
Red89maxima's Avatar
Don't turn it over! It doesn't take very long to take the top timming cover off, just pull the cover and take a look! And yes, it is worth it to buy as long as you can get it for relativly cheap.
Old Sep 4, 2005 | 08:58 PM
Greeny's Avatar
¯\(°_o)/¯
Most likely if it is broke the valves are already smashed......
Old Sep 4, 2005 | 09:12 PM
VEvolution's Avatar
I miss my VE
http://forums.maxima.org/showthread.php?t=417568 - Towards the end of this thread, I found out my timing belt snapped. And I didn't hear a bang when it happened.
Old Sep 4, 2005 | 09:17 PM
YEAH!! and if they're not? you gonna take that chance?
Old Sep 4, 2005 | 09:22 PM
Greeny's Avatar
¯\(°_o)/¯
Why not....It's not his car anyways......No need to yell about it....
And what do think this guy this guy did when he heard a "big bang" and the car died on him on the road......what anybody else would do....TRY TO RESTART IT.....
Old Sep 5, 2005 | 01:55 AM
so if the motor is messed up bad do have to replace the whole motor couldent you just replace the head??
Old Sep 5, 2005 | 03:22 AM
CBRKelly's Avatar
so if i'm reading some of these msgs right, if the timing belt *does* break on the VG30E... it causes your engine to smash to pieces right before your eyes? it doesnt just konk out or idle eratically or something simple? but complete destruction?
Old Sep 5, 2005 | 03:25 AM
Wiking's Avatar
Yes IF: problem is only bent valves. Quite certainly one or more pistons have holes.
Engine out, explode and inspect. If cylinder surfaces ok, repair might be only 500$... with that, u might get whole workin car.
Old Sep 5, 2005 | 07:29 AM
mattcomet82's Avatar
the vg30e is an interference motor. the valves and pistons are sooooo close that if the timing belt fails and some of the valves ar stuck open, they will get smashed when the piston comes around for it's exhaust stroke. the valves actually pop out into the cylinder a little when open.
if the bang was in fact the timing, cranking the key to find out won't hurt it, the damage is already done. if the bang wasn't the timing, cranking the key won't hurt either.
Old Sep 5, 2005 | 09:00 AM
4dscPat's Avatar
Even if it is broke, dont worry about it. Walk into any junkyard and you will have VGs ambushing you from every direction, begging to be taken hime. Like at a pet store. Seriously, they put this engine in just about everything for a good 10+ years.
Old Sep 5, 2005 | 09:20 AM
VEvolution's Avatar
I miss my VE
Also, very fast cranking is a good sign.
Old Sep 5, 2005 | 09:34 AM
and what if the timeing belt jumps teeth what happens there???
Old Sep 5, 2005 | 10:03 AM
Greeny's Avatar
¯\(°_o)/¯
Usually backfiring through the throttle body,no power,hard starting,etc.
That is for a one or two tooth jump.....More than that....not sure.
Old Sep 5, 2005 | 05:20 PM
vansskaterfreek's Avatar
just take the timing belt cover off.....you only have to take the top off and tug on the belt....its worth a shot
Old Sep 5, 2005 | 06:24 PM
slickblack94's Avatar
what motor came with a timing chain?
Old Sep 5, 2005 | 06:35 PM
Greeny's Avatar
¯\(°_o)/¯
92-94 se dohc engines have the chain...89-94 gxe's have the belt....89-91 se has the belt...
Old Sep 5, 2005 | 06:40 PM
Alex_V
Only the 92-94 SEs had the VE30DE which has the timing cain. All other se's and gxe have the VG
~Alex
Old Sep 5, 2005 | 10:37 PM
DanNY's Avatar
Ad·min·is·tra·tor
instead of bumping the starter...get a wrench on the crank and turn that instead and watch the dist rotor. (if you're THAT worried about the starter doing any damage)
Old Sep 6, 2005 | 05:21 AM
danielatgmail's Avatar
Okay place your bets - making a problem fun and interesting :)
My 89 max cut off on me last night.. so let's make this fun..
200k miles
going up hill and sounded like a carb back fire (without spark) or something (that's just what it sounded like, I know it's F.I.)
engine would turn but not fire up, battery stayed good. Only tried to start it about 3 or 4 times.
so having no light, no tools, and sprint roadside assistance.. no brainer.. tow it home ($6) and have a look at it today.
okay so who wants to test their knowledge... (or take a guess )
and see who's right, and can predict what the problem turns out to be?
Ahhhh let the "is it spark or is it fuel" investigation begin..
Old Sep 6, 2005 | 05:50 AM
Greeny's Avatar
¯\(°_o)/¯
200k miles
The info in this thread,the steps to take to find out if it is the t belt is all above......^^^^^^^^^^^^Good luck..
Start with this..http://forums.maxima.org/showpost.ph...41&postcount=2
Old Sep 6, 2005 | 07:46 AM
Hectic's Avatar
tow it home ($6)
$6 for a tow home? is that a $6 roadside assistance, insurance deductible? i have RSA on on my policy which is about $5 a month, but i'd be happy to drop it if i could get $6 tows only when i need them.
Old Sep 6, 2005 | 09:04 AM
It's $4 a month, which covers the hook up fee and the first 3 miles. I wasn't too far from home, a couple of exits up on the interstate, so after sprint took care of that, I had $6 left over charged to me.
But I still love this road side assistance deal.. For $4 a month (4x12=36 anually), I get 4 free "hookups" and first 3 miles for each one. So far I've used 3 this year, now.
used it twice on my old 86 e150. So it really pays for itself with the first usage. woohoo!
Old Sep 6, 2005 | 09:05 AM
oh and around here, hookups usually cost $75.. you could get lucky and find one for $40.. so it really does pay for itself.
Old Sep 6, 2005 | 01:22 PM
took off the dist cap. rotor did not turn. ugh! welp.. i'm either in the market for a 92-94 se dohc engine, or about to put the car on ebay. I have burgandy leather seats if anyone is interested. that sux. oh well. better close to home than on the road.
Old Sep 6, 2005 | 01:39 PM
Greeny's Avatar
¯\(°_o)/¯
There is a vg motor on ebay right now for $400......
Old Sep 6, 2005 | 02:06 PM
Not sure. I think it's an 89 gxe. has sun roof, no spoiler, drum rear brakes. I guess i'll pop the hood and check. thanks for the ebay check.
Old Sep 6, 2005 | 06:04 PM
just drop a junk yard motor in it.....you can get it cheap enough and you need no shipping..
Old Sep 6, 2005 | 06:30 PM
VEvolution's Avatar
I miss my VE
Go for the DOHC.. It's nice. Ate a 4th gen for dinner a few minutes ago. How much you plannin on putting the car up on Ebay for? My timing belt also snapped awhile ago, and lookin to get rid of the car for some pocket cash. Bodys real beat up though, so thats what makes it a bit harder. How much you plannin on given it up for?
Old Sep 6, 2005 | 07:04 PM
Hmm maybe I will drop a JY motor in it. I was thinking of putting it on ebay for like $400. Tranny is good and it has leather seats. glass and doors are good too.. but I might just drop a jy motor in it.. sounds like a plan..
Old Sep 6, 2005 | 08:52 PM
VEvolution's Avatar
I miss my VE
If the car looked and ran good before the incident, Im sure you should be asking more then $400 for it. My starting price will probably be $300. Or just drop another VG in there. If you still wanna keep the car that is.
Hondarydr
Dec 30, 2024 06:15 PM
tsi6001
Oct 3, 2022 10:23 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
Ray229Harris
Sep 16, 2015 08:16 PM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
