How do you install a tranny cooler in the max?
Old Aug 31, 2005 | 11:58 AM
Maxima Man's Avatar
Hey guys i would like to buy a transmission cooler but I need help to locate the two hoses I need to hook up thanks
If there is a install guide somebody made just please give me a link!
Thanks!!!
Old Aug 31, 2005 | 03:44 PM
internetautomar's Avatar
mod or sell?
you only tap into one hose going from / to the radiator.
doesn't make any MAJOR difference which one. I suggest running it through both coolers though (external and radiator)
Old Aug 31, 2005 | 03:59 PM
Sgibb's Avatar
Has anyone done a write up on this?
Old Aug 31, 2005 | 04:15 PM
max723's Avatar
theres a writeup for a 4th gen on the main page, not sure if its the same but should be prety similar
Old Aug 31, 2005 | 06:30 PM
Maxima Man's Avatar
No yhat write up is not the same
What fitting on the trans do you atatch to the trans return line from the cooler to ?
Old Aug 31, 2005 | 08:17 PM
MrSector9's Avatar
If you did it like internetautomart says then you dont have to attach anything to the trans from the ecxternal oil cooler...
You take one fo the lines coming from the tranny to the radiator,run it into you external cooler,take the line coming out of your external cooler and run it into the radiator where you took the first line off (the one running into the other side of your cooler)
This way it would run thorugh the rad then throguh the extra cooler or vice versa depending what line you used.
Old Sep 1, 2005 | 03:30 AM
kiyakerz's Avatar
advantages to cooling the tranny? is this for manual, auto, or both?
Old Sep 1, 2005 | 05:23 AM
mod or sell?
only applies to auto tranny and the benefit is theoretically longer trans life since the fluid tends to burn from overheating
Old Sep 1, 2005 | 05:26 AM
Maxima Man's Avatar
Ok I understand, now would that provide enough flow for the trans?
It is for an automatic
Automatics commonly fail due to high temps of fluid!
Thanks MrSector9 !
Old Sep 1, 2005 | 06:02 AM
DanNY's Avatar
Ad·min·is·tra·tor
Thanks MrSector9 !
unless you have a very restrictive cooler it should be fine for flow. now keep in mind if your tranny is on it's last leg the cooler won't do jack for you.
Old Sep 1, 2005 | 06:07 AM
Maxima Man's Avatar
What do you call last leg ?
It still shifts fine in all gears and can tear up the road on acell.
It shifts as smooth as can be expected except for 2nd gear.
but it shifts 2 hairs harder than the rest of the gears going into second gear!
Old Sep 1, 2005 | 06:11 AM
Greeny's Avatar
¯\(°_o)/¯
All these things you describe are the symtoms of a auto tranny on its way out to tranny heaven.....Sorry but true....
Old Sep 1, 2005 | 07:50 AM
DanNY's Avatar
Ad·min·is·tra·tor
are you serious?
if that's not a good indication of a healthy tranny then i don't know what is.
2nd gear solenoid might* be acting up..but that's about it for the moment.
Old Sep 1, 2005 | 08:09 AM
Greeny's Avatar
¯\(°_o)/¯
[QUOTE=DanNY]are you serious?[/QOUTE]
Yes....I have owned many Autocrapic vehicles in my time...And in all of them Autos when they started shifting funny,It wasen't very long after that they failed all together....But this is just my experiences with the autos i have had....I hope i am wrong and his tranny goes on for a long time ....
Old Sep 1, 2005 | 08:18 AM
DanNY's Avatar
Ad·min·is·tra·tor
[QUOTE=MyGreenMax94]
if it shifts funny it's usually a constant issue...or it occurs in all gears...that's when i can say that it's on it's last leg....but if he can accel and tear it up fine then there's nothing to worry about.
what he's describing is more a shift quality/comfort than the actual tranny shifting into the next gear.
Old Sep 1, 2005 | 10:03 AM
Maxima Man's Avatar
Hey Guys, Yeh you are right DanNY the transmission is not having a problem changing into second gear it just shifts a little hard.
The other gears are smooth as slik and I can put the pedal to the floor and It will shift into all gears very quickly and smoothly.
It is only when I do a slow laid back acelleration when it shifts a little hard!
I heard about these coolers and wanted to install one
Will cleaning and adding contact grease to the transmission electrical conections help get the proper amount of juice to the 2nd gear soloniod to perhaps smooth out the shifting ?
What is the best one or name brand for tranny coolers?
Thanks Guys !!
Old Sep 1, 2005 | 10:31 AM
DanNY's Avatar
Ad·min·is·tra·tor
Thanks Guys !!
contact grease wouldn't hurt anything...but i don't think it'll do too much for you.
i personally like the B&M coolers..they are built better.
change the fluid before you put the cooler in.
Old Sep 1, 2005 | 10:50 AM
Maxima Man's Avatar
I just had the fluid changed so i think i will be good
When I install the cooler i will top the fluid off to the full mark!
What does B and M stand for ?
Thanks DanNY
Old Sep 1, 2005 | 11:18 AM
Sgibb's Avatar
where can you get a tranny cooler?
Old Sep 1, 2005 | 11:23 AM
DanNY's Avatar
Ad·min·is·tra·tor
Thanks DanNY
B&M is a company.
where to get it...http://www.summitracing.com/
http://store.summitracing.com/defaul...=egnsearch.asp
god you guys are lazy
Old Sep 1, 2005 | 11:45 AM
Greeny's Avatar
¯\(°_o)/¯
If you live close to them guys danny you could install it for them....j/k
Old Sep 1, 2005 | 11:49 AM
Maxima Man's Avatar
Very funny! (myGreenMax94)............
I just thought it would be easier searching for a company name not just initials!
Thanks DanNy for the link lol
Old Sep 1, 2005 | 12:01 PM
CyMax's Avatar
Thanks!!!
Only two things to add for you. Get the biggest you can fit, I think the one I had on my PGT was for a full blown RV expected to tow another car. Also, I agree with the earlier poster about running the lines first through the rad, then the cooler. Oh and don't forget to top off your tranny fluid, there will be more needed to fill all the lines in the cooler. I know sort of a duh reminder, but sometimes we all need them. It's really like a 10-20 min install, easy and your tranny will thank you.
Old Sep 1, 2005 | 12:20 PM
DanNY's Avatar
Ad·min·is·tra·tor
B&M is the company's name
Old Sep 1, 2005 | 12:25 PM
DanNY's Avatar
Ad·min·is·tra·tor
depends on where you live...if you're in a colder climate a big cooler might keep the ATF too cold for the tranny to shift properly
Old Sep 1, 2005 | 12:42 PM
Greeny's Avatar
¯\(°_o)/¯
And a very long lived well respected company in the aftermarket transmission market....I remember my dad putting a b&m shifter in his 66 rustang...When i was around 8-10 yrs old.....
Yup im old......
Old Sep 1, 2005 | 12:58 PM
Maxima Man's Avatar
I was unable to quickly find the coolers on that web page but i am sure I can find them else where on the web !
This is probobly a dumb question but when you mount the tranny cooler infront of the radiatior dosent the air flow become restricted over the radiator and cause the engine to run hotter?
Thanks Guys
Old Sep 1, 2005 | 01:14 PM
Greeny's Avatar
¯\(°_o)/¯
Thanks Guys
Naw....Tranny coolers are small in size [average 3"wide-12" long] So they won't interfere with your radiadtors ability to cool the car....in theory it should aid in cooling because the rad. doesn't have to keep tranny fluid cooled down as much......
Old Sep 1, 2005 | 01:27 PM
Maxima Man's Avatar
The b and m cooler i am looking at is 10 by 6 inches is that to large ?
I don't want an overheating engine!!!
Thanks for your prompt replys!
Old Sep 1, 2005 | 01:47 PM
Greeny's Avatar
¯\(°_o)/¯
Nope...Won't hurt nothing.....
Old Sep 1, 2005 | 01:58 PM
DanNY's Avatar
Ad·min·is·tra·tor
Thanks Guys
there's a search box on the summit web site...yes SEARCHHHH...
type in B&M coolers and all the coolers will appear
just TRY and use the search...and please TRY to look for information on your own. like greenmax said...if i gave you any more information i'm going have to go and install it on your car.
oh and before you even ask...the lines are 5/16...3/8 would work also...make sure the fittings/adapters are sized correctly.
Old Sep 1, 2005 | 06:18 PM
Maxima Man's Avatar
Thanks DanNY
I apprecitate your time and efforts !!!
Old Sep 1, 2005 | 06:23 PM
Greeny's Avatar
¯\(°_o)/¯
Thanks DanNY
He is pretty handy too have around.....Plus he owns me on his every visit.....Maybe i should stop posting here..
Old Sep 2, 2005 | 06:37 AM
DanNY's Avatar
Ad·min·is·tra·tor
...it's all done in good fun. i'm not here to "own" anyone...just trying to keep the peace and help out members (when i can)
Old Sep 2, 2005 | 10:15 AM
Maxima Man's Avatar
Thanks guys
Old Sep 2, 2005 | 10:22 AM
Greeny's Avatar
¯\(°_o)/¯
No offense taken....I know your just busting my chops..
Old Sep 6, 2005 | 10:29 PM
Pyrophilus's Avatar
I think it's more unrealistic for someone to ask, "how do I know my tranny is on its way out?" than the folks here trying to tell them what to (or not to) look for.
I have had slight hard 2nd gear shifting on my '92 GXE for as long as I can remember (and that's even before I got my license (family car purchased new in '92)). It is still running okay.
I had a 1997 Pathfinder SE that had slight hard shifting into second gear. This started at 30k mi, and I drove the car 108k miles in 3.5 years. Traded it in for a 2001.
The 2001 also developed slight hard shifting into 2nd gear, and by this time, I am thinking this is normal... At 42k miles, my transmission refused to shift into 3rd (4 speed auto). Got a brand new tranny under warranty, and after another 30k miles, I seem to notice ever slight hard shift into 2nd again.
Maybe it's my driving style, albeit the hard shifting on the Maxima started before I even drove the car...
Anyway, what do I think is a sign that the tranny is on its way out? If you find that you are chugging along the parkway at 25MPH because you are stuck on 2nd gear? Oops, I guess by then it has gone out...
dank4us
34
Jun 10, 2024 03:45 AM
Cotozic
Jun 28, 2017 08:01 PM
Ray229Harris
Sep 16, 2015 08:16 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Supragte
Aug 12, 2015 10:00 PM
