Ok....so should I advance my timing?......
Old May 27, 2001 | 12:52 AM
Mike S.'s Avatar
An ecu is out of the question....500 isn't worth it on a 93. If I bump the timing will I feel a difference in low end? high? How much? Is 20BTC too far?
Mike S.
Old May 27, 2001 | 04:15 AM
Nismo87SE's Avatar
Do you have the FSM? There is more to adjusting the base ignition timing than turning the distributor. I believe you have to unplug the TPS and rev the engine about 3 times from 3k-4k to lock in base timing. Since stock is 15BTDC, I say try 17-19BTDC. For the SR20DE bumping the timing from stock 13-15BTDC to like 17-19BTDC nets around 3-6fwhp, but the SR20DE runs 15 BTDC on 87 octane. You should notice better throttle response with advanced timing.
Mike S.
Ben2003GLE
31
Jul 17, 2016 08:13 AM
kmitchel
Oct 28, 2015 09:46 AM
Starrider
Sep 17, 2015 07:26 AM
rbaker100
Aug 31, 2015 11:09 AM
305head
Aug 26, 2015 09:03 PM
