How much did auto-to-manual swap cost you?
Old Sep 9, 2005 | 08:31 AM
Hornswoggler's Avatar
Just curious, for all those who have swapped from auto tranny to manual, what it cost and about how much time did it take?
I do not have a garage right now (building a house, but in apartment for now) so I don't have the space to DIY right now... so I might have to take it to a shop.
My auto tranny is slipping. I think it has a leak as the fluid has been low too. It also clunks when I put it in reverse.
I assume its cheaper to just repair the current auto tranny, but I might pay a few hundred more for the swap. If the total bill gets over $500, imma just fix the existing auto or find a different car.
Any suggestions? I did get some links from other threads, seems to be quite popular these days :-)
Old Sep 9, 2005 | 08:34 AM
tripleGmax's Avatar
um fixing an auto can get well over 500 dollars.
Old Sep 9, 2005 | 08:40 AM
Do you seriously think so? What kinda parts or labor will take it over $500?
I can picture the dealer charging that much with just labor alone, but I would find an independant shop for less.
Old Sep 9, 2005 | 08:49 AM
Mizeree_X's Avatar
Getting back to his roots
Rebuilding a tranny costs $1-2k. I suppose you could buy a junkyard auto tranny for less than $500.
Old Sep 9, 2005 | 08:57 AM
Dang. that sounds expensive.
Anybody have an idea what it costs to swap in a used manual transmission?
Old Sep 9, 2005 | 09:13 AM
subs1000w's Avatar
if you go to a junkyard and get all the parts it can be done for under 200$
but when you start replacing and upgrading things is when it starts to add up
things like the axles $60-80 a peice and there are 2 the clutch 100-300 and master 20-30 and slave cylinder 30-40 should all be replaced for maximum reliability also these transmissions have input shaft bearing issues and ive received 4 trans from various junkyards and all had bad input bearings and even though they are still usable i would sugest replacing that also. the bearing is only like 50$ but the labor would be alot if you couldnt do it yourself
Old Sep 9, 2005 | 09:14 AM
Greeny's Avatar
¯\(°_o)/¯
Go to...http://www.car-part.com/ and check used prices on all the stuff you need for the swap.....
Old Sep 9, 2005 | 09:21 AM
Lemme ask this:
Will ANY 3rd gen manual tranny fit my 93 GXE? I assume it will, but just double checking.
Old Sep 9, 2005 | 10:51 AM
Greeny's Avatar
¯\(°_o)/¯
Lots of info in this....STICKY!
http://forums.maxima.org/showthread....ht=swap+sticky
Old Sep 9, 2005 | 03:18 PM
subs1000w's Avatar
Lemme ask this:
preferably a VG 3rd gen 89-91
92-94 will work but you will need to swap wheel hubs too
Old Sep 9, 2005 | 03:32 PM
maxitech's Avatar
Did the 89-91 5-speeds have the VLSD?
Old Sep 9, 2005 | 03:48 PM
internetautomar's Avatar
mod or sell?
no they didn't
Old Sep 9, 2005 | 04:21 PM
MrGone's Avatar
You aren't going to get a quality rebuild for $500 on an auto unless you know the guy doing the work.
If you play your cards right you can get 5spd swap stuff dirt cheap
For the VE tranny to a VG
http://forums.maxima.org/showthread....ighlight=axles
no, 89-91 5spd transmissons do not have LSD, only 92-94 SE's had the option.
Yes all 3rd gen transmissions will physically bolt up to either engine
search is your best friend.
Old Sep 9, 2005 | 04:52 PM
That's funny, search seems disabled for me. :-(
Old Sep 9, 2005 | 04:54 PM
MrGone's Avatar
http://forums.maxima.org/showthread.php?t=268739
Old Sep 9, 2005 | 05:33 PM
Well, aren't you 100% defensible???
You can tell me to search, and ANYTHING I can reply back with, you already have a smart-*** link to post. I bet you had that url in your clipboard (copied) before I even replied...
Back to the topic. I cannot search so I have to ask these questions over again.
Old Sep 9, 2005 | 05:37 PM
Greeny's Avatar
¯\(°_o)/¯
If you can afford to put a half a tank of gas in your car then you can donate $25 to search for all the answers to your questions......
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
