Timing Belt Change?
Old Sep 9, 2005 | 01:48 PM
str8max's Avatar
Timing Belt Change?
How do you know when its time to change it?
I have a 90 GXE with 82K and I have only had it about a month got a deal $1500 and its very clean. So when I got it I did general maintenance on it plugs, wires, dist. cap, rotor button,and fuel filter but now it seems to have some hesitation but has tons of power...any ideas?
thanks
Old Sep 9, 2005 | 02:27 PM
Greeny's Avatar
¯\(°_o)/¯
Now.........
The recommeded change interval is 60,000 miles i think so if it is the orginal then its time.....
Old Sep 9, 2005 | 03:45 PM
internetautomar's Avatar
mod or sell?
yup, unless you know for a FACT that it was changed (reciept for proof)
change it NOW!!!!
Old Sep 9, 2005 | 06:28 PM
str8max's Avatar
is it diffiicult to change?
Old Sep 9, 2005 | 06:43 PM
Greeny's Avatar
¯\(°_o)/¯
That all depends on your mechanical experience...Since you ask the question, that tells me that you do not have much experience...
Check the repair information in the stickies for more info.
Old Sep 9, 2005 | 06:53 PM
str8max's Avatar
I am pretty good with cars just not with time...what is the average cost in having this replaced?
Old Sep 9, 2005 | 07:10 PM
Greeny's Avatar
¯\(°_o)/¯
Probably $200-$400 range.......
Old Sep 9, 2005 | 08:23 PM
mattcomet82's Avatar
if you have the right tools, a little experience, and plenty of patience, it's a walk in the park. if you're missing one or all of these, your swearing will increase tenfold. a factory service manual is a good investment if you plan to perform any maintenance such as this. small things can be easily overlooked that can cause major problems, so be sure to check your work twice before moving on.
Old Sep 9, 2005 | 11:41 PM
CyMax's Avatar
Yep, he's right. PM me if you need the FSM portion of that equasion.
Old Sep 10, 2005 | 01:24 AM
Wiking's Avatar
...some hesitation but has tons of power...any ideas?
- belt swap, 60k, 5yrs
- "I have a 90 GXE with 82K" ... me too
- "it seems to have some hesitation" ... I had also. All is well after 'some' tuneup: http://www.cardomain.com/ride/748507/1
- for belt change, what ppl say. Also check my Favorite Links. On tightening, concentrate only on how to verify tightness; 20lb push force bends belt under half inch.
Old Sep 11, 2005 | 08:22 PM
ArcticDC5's Avatar
Does anyone want to help me with my belt change here in MD?
Old Sep 12, 2005 | 01:00 PM
Governor's Avatar
Not sure but if u have a 91 SE then you have a chain not a belt..one of the guru's in here may be able to confirm..if so u dont need to change it....
Old Sep 12, 2005 | 01:02 PM
Governor's Avatar
good write up on VG30 timing belt replacement
http://sadik.net/nissan/howto/tbelt.htm
Old Sep 12, 2005 | 01:03 PM
Minty91GXE's Avatar
no, not until 92
Old Sep 12, 2005 | 01:05 PM
Governor's Avatar
Originally Posted by Minty91GXE
no, not until 92
I stand corrected..thanks
Old Sep 12, 2005 | 02:55 PM
slickblack94's Avatar
does the 94 es have a chain or belt i have 225,000 and thinking maybe here in about 75,000 i might change something. Just dont know if its rubber or metal lol
Old Sep 12, 2005 | 04:26 PM
Minty91GXE's Avatar
if youre an SE, with the VE engine, you're a chain.
Old Sep 12, 2005 | 06:58 PM
mod or sell?
no, not until 92
actualy from 7/91 they switched over.
yes my car is a 7/91 production date
and my last max was 6/84 production date (last rear wheel Drive max)
Old Sep 12, 2005 | 07:27 PM
Minty91GXE's Avatar
do they call it the 92 model?
Old Sep 13, 2005 | 07:02 PM
mod or sell?
7/91 is considered a 92 model year maxima
Old Sep 13, 2005 | 07:41 PM
ArcticDC5's Avatar
I know that I am going with an oem nissan timing belt.
My question is am I safe going with aftermarket tensioner, water pump?
Old Sep 14, 2005 | 05:15 AM
mod or sell?
the question is not aftermarket, as it is all aftermarket, it is whether a particular brand is worth a squat
Old Sep 16, 2005 | 12:00 PM
ColombianMax's Avatar
Hey I just bought myself a 93 maxima. nice deal only $550 but needs a timing belt too, for those who have changed it before at a shop, how much does it usually run for?
Old Sep 16, 2005 | 12:12 PM
DanNY's Avatar
Ad·min·is·tra·tor
post number 7.
read the thread...THEN post.
Old Sep 16, 2005 | 12:13 PM
DanNY's Avatar
Ad·min·is·tra·tor
IMO i would get the OEM everything...but that's just me.
Old Sep 16, 2005 | 02:03 PM
CyMax's Avatar
My curosity begs me to ask,,,, Should I ever have to change the Timing chain??
Old Sep 16, 2005 | 03:49 PM
mod or sell?
yup it needs to be changed every 3k along with your oil.
Old Sep 16, 2005 | 04:47 PM
Greeny's Avatar
¯\(°_o)/¯
Oooops I knew i was forgetting something all these years
Old Sep 16, 2005 | 06:35 PM
maximagxe90's Avatar
bryan was planning with you guys,
the timming chain does not need to be replace, because it should last the life time of the engine,
Old Sep 16, 2005 | 06:51 PM
Greeny's Avatar
¯\(°_o)/¯
So...Brian whats the plan..Gonna run a special on timing chains so i can catch up on my oil change,timing chain replacements...
Old Sep 16, 2005 | 07:10 PM
Governor's Avatar
Originally Posted by DanNY
post number 7.
If its al ready broke you may need more than the belt!
Old Sep 16, 2005 | 08:26 PM
CyMax's Avatar
Ok, ok nuff with the newbie stuff, I was just posing the Q. Just trying to drum up a few $$$ huh? I'm sure I could sell a few for, well mabye store credit . JK!!!
Old Sep 16, 2005 | 11:07 PM
No its not, still runnin but needs to be changed soon or engine will be going out as my g/fs dad said.
Old Sep 17, 2005 | 06:53 PM
mod or sell?
I'll put together a group buy
Old Sep 18, 2005 | 11:05 AM
twinkle's Avatar
but a timing belt also lasts the lifetime of the engine, cause when it breaks the engine is dead....
tsi6001
Oct 3, 2022 10:23 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
laparka66
Aug 6, 2015 09:36 AM
RealityCheck
Aug 5, 2015 06:18 AM
