Wash car and now no lights!!
Old Sep 10, 2005 | 04:39 PM
CyMax's Avatar
Ok I went and washed the car, dried ect ect. Get in and nothing. No corner lamps, no headlights, no foglights, turn signal works as well as the set of driving lamps I installed. The lights in the dash seem to be possessed as well. They came on and off on the way home then when I turned the lights off the dash lights stayed on!! WTF????? It's too dark now to screw with it, but HELP!!!!
Old Sep 10, 2005 | 07:17 PM
internetautomar's Avatar
mod or sell?
check the taillights.
corrosion in the rear sockets can cause some funny problems.
Old Sep 10, 2005 | 07:27 PM
Greeny's Avatar
¯\(°_o)/¯
I had a old celica that did that every time i washed it....Then the next day it was alright...
Old Sep 10, 2005 | 11:57 PM
Wiking's Avatar
Originally Posted by CyMax
...It's too dark now to screw with it, but HELP!!!!
Fishermen get fish cause they can think like a fish. Here fish must think where the water could have gone in and how reached and what. Sometimes it seems to have veeery complicated routes. As said, I'd start from rear lamps, then dive under dash and seek for soaked places.
Future: Pry windshield seals somewhat open all around, check for possible leak points. Take cloth, dry/clean under seals all around from there, inject silicone.
Old Sep 11, 2005 | 12:18 PM
CyMax's Avatar
Ok checked fuses now that there is light outside. Both the taillamp fuse and the headlight fuses were blown. Replaced the headlight fuse, works fine, but I replaced the taillamp fuse and all it did was blow as soon as I turned the lights on. I checked both the lamp assemblies, no sign of water anyuwhere. Ideas?????
Old Sep 11, 2005 | 05:12 PM
mod or sell?
lookc for corrosion in the sockets themselves
Old Sep 12, 2005 | 02:16 AM
Wiking's Avatar
...replaced the taillamp fuse and all it did was blow ...
Halve the problem:
1. Unplug rear lamps
2. New fuse,
3. put lights on.
4. Fuse blown?
Yes= harness, front switch etc problem - rear lamps ok
No. Either rear assy shorted. Install RH lamp, put lights on.
5. Fuse blown?
Yes= RH rear lamp faulty
No. RH rear lamp ok! Install LH lamp, put lights on.
6. etc
7. What all devices are connected in taillamp fusing, take out one by one, test...
--->?shorts in drivers door...
clic on http://www.cardomain.com/ride/748507/5
Old Sep 12, 2005 | 04:45 PM
CyMax's Avatar
Yep it's the 1157 light sockets in the rear. To be exact it's ALL 4 of them!!! All of them have one contact totally crispy critters, and the other one is ok. So where can I find 4 replacement Nissan 1157 sockets in like a day?
Old Sep 12, 2005 | 04:49 PM
Greeny's Avatar
¯\(°_o)/¯
I can ship you the rear lights off my parts car.....Overnight or something...
Old Sep 12, 2005 | 04:58 PM
Greeny's Avatar
¯\(°_o)/¯
Is this what you need?
Old Sep 12, 2005 | 06:59 PM
mod or sell?
the assembly has to be from a 92-94 only 89-91 does not work/fit
it is sold as an assembly
Lakersallday24
Jun 16, 2019 01:35 AM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Samedi
Aug 13, 2015 04:05 PM
altome15
Aug 10, 2015 07:05 PM
yat70458
Aug 3, 2015 01:16 PM
