Cryo treatment
Old Sep 16, 2005 | 10:59 AM
Akuma2001's Avatar
Cryo treatment
has anybody heard of cryo treating any part of the car and getting better gains in any way? I know that it hardens the metal which would allow for slightly more sustained abuse.
The reason I'm asking is because my friend is in this Automotive technical school and there is a Cryo freezer there so I got an .
Old Sep 16, 2005 | 11:02 AM
Jeff92se's Avatar
I'm needing a caw
It doesn't harden the metal. Sorry..
Old Sep 16, 2005 | 11:10 AM
Akuma2001's Avatar
I was reading an article in Turbo Magazine that they wanted to knifeedge the crankshaft that they already cryo treated and the people at the machine shop said it took an extra 2 hours to do the job. In the article itself they said to do cryo treatment last in order to save time.
Old Sep 16, 2005 | 11:13 AM
Jeff92se's Avatar
I'm needing a caw
Researchers have found that the effects of shallow cryogenic tempering (-110°F) is minimal unless it is performed as part of the initial heat treat cycle. Heat treating is what gives steel its hardness as well as its toughness, wear resistance and ductility. Even performed properly, heat treating cannot remove all of the retained austenite (large, unstable particles of carbon carbide) from a steel. Proper heat treating is a key part in increasing a parts toughness, durability, wear resistance, strength and Rockwell hardness.
The beneficial changes that occur as a result of the heat treat process do not actually take place during the heating, but, rather from the cooling or "quenching" from the high temperature. (The benefits of the quench do not stop at room temperature, as many alloys will continue to show significant improvements as the quench temperature nears absolute zero.) While it is impossible to actually achieve -459.67°F, (a molecular zero movement state that eliminates all stress), deep cryogenic tempering temperatures are very efficient and cost effective in increasing dimensional stability, increasing wear resistance and performance of most alloys.
Old Sep 16, 2005 | 11:18 AM
Akuma2001's Avatar
So therefore I will derive some benefit from cryo treatment.
Does anybody have a clue as to what parts are recommended to cryo treat?
Old Sep 16, 2005 | 12:21 PM
DanNY's Avatar
Ad·min·is·tra·tor
engine blocks and parts
tranny parts (gears and etc)
brake rotors
and unless you're doing something crazy with your motor you derive very little benefit from it. only thing i would say to throw in is the brake rotors.
Old Sep 16, 2005 | 12:31 PM
Akuma2001's Avatar
brake rotors
By cryo'ing the engine's internals would that allow for a higher rpm?
Old Sep 16, 2005 | 12:33 PM
MrGone's Avatar
not really
Old Sep 16, 2005 | 12:52 PM
DanNY's Avatar
Ad·min·is·tra·tor
why would you think that?
Old Sep 16, 2005 | 12:53 PM
Jeff92se's Avatar
I'm needing a caw
Cryo the oil, that's internal.
Old Sep 16, 2005 | 01:08 PM
Akuma2001's Avatar
Because of the heat stress that occurs when raising the redline. When a car in the redline for too long the temp. goes up. Maybe because the internals were cryo-ed therefore it can withstand a higher stress levels.
Old Sep 16, 2005 | 01:43 PM
DanNY's Avatar
Ad·min·is·tra·tor
did you really read Jeff's post? cryo makes it more wear resistant...but it doesn't really make the metal tougher or harder. it would improve wear on the items that are in the engine...IE piston, cranks, etc.
Old Sep 18, 2005 | 01:24 PM
Dillbag's Avatar
Suprise butsechs!!!
Basically it's for hardcore race motors to improve durability when running a motor within an inch (or an rpm) or it's life. Like they said, unless you plan on building a motor for massive amounts of boost, it's really unnesessary. But I have read in race mags where cryo-treated brake rotors lasted substantially longer, IN RACE CONDITIONS. Might be good for the crappy internals of the 3rd gen auto trans.
Old Sep 18, 2005 | 08:22 PM
Matt93SE's Avatar
STFU n00b!
meh.. I cryo'd my last set of skyline rotors on my Max. they still cracked in about the same time the plain ones did... same part, same brand (OEM)...
there are certain parts of the car that would benefit from cryo treating, but if you're having to ask us these questions, you don't need to be digging that far into your car to do it.
Old Sep 19, 2005 | 06:59 AM
Brad92SE's Avatar
Shot-peening parts would probably have better benefits than just cyro-treating. As has been said, cyro treatment only affects the wear resistance of the parts, not the ultimate strength. I think thats correct anyways.
Old Sep 19, 2005 | 08:36 PM
Dillbag's Avatar
Suprise butsechs!!!
I think brad has the most apt explanation.
oh and Matt, u be a hard brakin' fool.
Old Sep 19, 2005 | 08:39 PM
Greeny's Avatar
¯\(°_o)/¯
He has got a sweet video of him at the track....I wish he would post it again...
Old Sep 19, 2005 | 08:52 PM
Matt93SE's Avatar
STFU n00b!
Meh.. they're not that impressive.. I haven't had a camera to play with in quite a while. I'm much better than I was when I took these vids.
Motorsport Ranch- near Dallas, TX. 25MB:
http://blehmco.com/movies/me_at_msr_3.WMV
Texas World Speedway, College Station, TX. 16MB.
http://blehmco.com/movies/me_at_tws_1.wmv
Old Sep 19, 2005 | 09:10 PM
Greeny's Avatar
¯\(°_o)/¯
Thanks matt...I saved them this time....My two boys will love to watch them....
Then tell me " When can we do that dad"
Old Sep 20, 2005 | 05:30 AM
internetautomar's Avatar
mod or sell?
saved, I needed those vids a bit back
rbuswell
Nov 17, 2016 04:54 AM
16_SR
Sep 7, 2015 06:47 AM
Tha'-Max
Aug 30, 2015 01:14 AM
ericdwong
Jan 11, 2002 10:03 AM
ericdwong
Jan 7, 2002 09:52 AM
