do i need new window motors?
Old Sep 18, 2005 | 09:29 AM
West.Six's Avatar
in the winter my windows roll up really slow. why is that? I have replaced the regulators and oiled them but it dosn't seem to help. Do I need to replace the motors or would that be a waist of money?
Old Sep 18, 2005 | 09:54 AM
Wiking's Avatar
Originally Posted by West.Six
in the winter ... why is that? ...
If all four behave the same way, it points to a common problem.
- check charge voltage, maybe low? (13.8-14.6V). Check supply voltage also from drivers door, from motor connections while running window(s) up... If voltage is a problem, give direct supply from a healthy batt to the motor connector and see if any speed difference.
- connector(s) oxidized in input supply wiring
- grounding points oxidized
- circuit breaker bad at smj (voltage heat loss)
- motors wear down only if constantly used. Rusting/Water is more problematic... Should last 'car lifetime' -if- mechanism is kept well oiled. Needs maint minimum once in 4yrs, depends on where the car sits.... But if already replaced, maybe needs only window guide lubrication?
see door related schemas at: http://www.cardomain.com/ride/748507/13 also check Favorite Links top left.
Old Sep 18, 2005 | 02:26 PM
rrrfoma's Avatar
Originally Posted by WikingBut if already replaced, maybe needs only window guide lubrication?
see door related schemas at: [url
http://www.cardomain.com/ride/748507/13[/url] also check Favorite Links top left.
I agree - window guide lubrication is your problem
AaronL
Aug 8, 2020 10:31 AM
Fbana41
Aug 29, 2016 12:18 PM
D Mason
Jun 21, 2016 04:43 AM
