Timing belt changed
Timing belt changed
Well I did it.....took the day off work and changed the timing belt....all I can say is whoa!!!!!!!
thats a lot of damn work...also changed all belts and hoses while I was there....also found that I have a bad injector which i will replacing soon.
Sure am glad its over.....the belt was actually in good shape no broken teeth or anything.
Maxima 92 Problem
Hello everybody, I am new at this forum, and well I have a question, and I believe is related to the same issue, timing belt.
the car used to run great, but after the timing belt got change, it started stalling and doesn't go any further than 2000 RPM, at 55 MPH it stalls and sometimes dies. I reemplace the distributor cap and the inside rotor, and of course the belt and the fuel filter, any ideas that you might have? Thanks
Max
Max
Max
Max
Try looking at the mass air flow sensor harness/plug ,make sure it is connected and in good shape...
If it looks good then i would replace the maf.....try a used one at a junkyard or check out the 3rd gen. for sale section.....http://forums.maxima.org/forumdisplay.php?f=62
Originally Posted by falseicon
i think i read that in a fourtune-cookie the other day
too funny wiking
too funny wiking
1860 local newspaper had 'scientist predict' that if development continues, Helsinki will be deep under horsesh1t after 100yrs. Well, hell sink in -did not happen. But those 'scientists' evoffspring still cont to get paid with similar **** predictions; www.junkscience.com ...and we PAY dearly.
max81 ..."after the timing belt got change, it started stalling and doesn't go any further than 2000 RPM"
- when some critical sensor fails, ECU drops to safe mode, =2.2k rpm limit. Could be MAF as grnmax says. Test the sensors: http://www.cardomain.com/ride/748507/1 --->page 9
- distributor gnd not working, wire off (causes warped cam sensor pulse)
http://www.cardomain.com/ride/748507/10
berncity1711 "...turn and go over small bumps while turning...opinions please....."
- somewhat off the thread issue?
- swaybar is typically affected also while driving straight. Worn lower arm bushing, ball joint?
Max
Max
Originally Posted by berncity1711
oh and i hear a knocking when i turn and go over small bumps while turning( but not when i go over a bump straight on tho), i think it could be the front sway bar but not absolutely sure....opinions please.....
its alot of work but its worth it in the end. luckily my t-belt from my old '93 motor which is now in my '89 had cracked teeth but not missin' teeth. a little longer and that motor would have said BYE.
Originally Posted by ArcticDC5
About to do mine next month. Doing the t-belt, tensioner, h20 pump, front main seal, cam seals and acces. belts.
Originally Posted by Governor
Same here......my water pump is ok though....I will have the crankshaft and camshaft seals ready if needed......weather permitting..working outside ya know...
Originally Posted by ShortFuse
If changing a t-chain is anywhere near as hard as changing a thermostat is (I'm sure it's crazy hard) my hat is off to you. I had serious problems with the t-stat. Gave up and had the dealer do it.
Its not hard just time consuming....have to go through wheel well..tight fit...long day...very stressfull repair but will save about $400 labor and dat buy alot of gas....
mmmmm.....gas... I need a lot of it, my maxipad took down 43 bucks like nothing giving me 15.5 mpg...now its a 16.2 mpg with same driving condition.
mmmm....400 bucks of gas sure do sound good...
tsi6001
Oct 3, 2022 10:23 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
laparka66
Aug 6, 2015 09:36 AM
RealityCheck
Aug 5, 2015 06:18 AM
congratulations
