CV Joints
Old Sep 23, 2005 | 02:39 PM
avusblue92se's Avatar
CV Joints
Hey all. I am going to change out the passenger side cv joint this weekend. It seems to be pretty straight forward. Do I need to buy pivoting angle sockets? About how long? It looks like three of the bolts are at a reach. Thanks for any advice.
Old Sep 23, 2005 | 04:00 PM
Greeny's Avatar
¯\(°_o)/¯
yea...I won't hurt to get some U joint type pivot extensions...
Separate at this point from the axle support
Old Sep 23, 2005 | 04:50 PM
Hectic's Avatar
have lots of fun.
Old Sep 23, 2005 | 05:53 PM
falseicon's Avatar
once ya do get those bolts off, that support bearing bracket can be a real pia.
I followed some org advice and pre-doused the whole deal with pb-blaster the night before. once the bolts were off (and if you don't have a lift) you can drop a long crowbar down from the top, line it up on the section closer to the wheel (look at the pic) and hit at an angle till it turns. once you get it to turn you can seperate it with some effort like in MyGreen's pic.
yeah, have fun
Old Sep 23, 2005 | 06:52 PM
wolfpack_5150's Avatar
Apple Pie Monster
If you can do both, some things should just be done in pairs. More than likely you will be replacing the other soon.
Just my $0.02
Old Sep 23, 2005 | 07:04 PM
sounds good. It does seem like it is going to be a blast. I intend on doing the other side really soon. The passenger one is completly shot, though. So you suggest using a crow bar to separate the joint from the support. Well thanks I may back on tomorrow asking for more advice.
Old Sep 23, 2005 | 11:01 PM
falseicon's Avatar
1st line up the crowbar to hit it on an angle, you want to position it so the hammer shots will spin the thing, once it turns the bonds will be weaker and you can seperate the two with a wedge.
Old Sep 23, 2005 | 11:09 PM
95turbo gxe's Avatar
Its not that bad to get them boilts off. Just take some extentions with you and try differant ones.
James92SE
142
Jan 2, 2024 09:23 AM
user 11122324
42
Jul 18, 2022 03:35 PM
AaronL
Nov 15, 2020 11:52 AM
ivorton23
Sep 26, 2015 09:47 AM
Bonka
Sep 14, 2015 11:18 PM
