Pressure Release from Gas Cap
Just wondering why I get a loud pressure release sound when I open the gas cap on my 92' VE every time, but never had it in my 93' VG? Did they change something in the later models that made that stop, because a few have told me it's pretty normal since the system is pressurized. Thanks in advance.
Originally Posted by Joe Fontinyatz
Oh okay, so it most likely has to do with the cap. Im gonna swap the GXE cap into the SE, see what happens. I'll chime in later with the results.
the filler vent tube is also prone to leaking on these cars. it's the ~1/2" hose running next to the large filler tube.if that thing is leaking, then the system won't build pressure.
and yes, it's completely normal for the system to build pressure... one of the many reasons is that it keeps oxygen out of the gas tank to prevent explosions in severe accidents. no oxygen= no fire
If the system won't vent pressure, you have a leak somewhere- either a bad gas cap or hose is leaking.
Thanks for all the help guys.. Thankfully my current car(SE) is the one that actually releases pressure when the gas cap is opened. The time beltless GXE is the one that never made any noise which most likely had some leak. Interestingly enough though, the car had amazing fuel economy. Then it was probably the cap.
In Texas, we need to have state inspection once per year and the last time I was at one of the places that perform the inspection they did not pass a car which does not have the gas tank presurelized. They told the lady to go buy a new gas cap and come back latter.
I was re-reading this thread and got a bit confused. I assume that most cars around do have pressurized fuel systems. From the many cars I have driven and filled up, I have never heard this pressue release sound from any car when the cap is opened. So there is most likely a leak goin on in all cars or they have a bad gas cap is what I understood from this thread. Cause some of these cars are actually new. Thats why Im a little out there on the subject. Any ideas?
some cars don't run the same pressures that we do, or the fill tubes are different, etc etc etc... some simply don't make the sound when you pull the cap off.
I know my chevy truck doesn't, but if you put your hand over the fill tube, you can feel the fumes coming out.
my altima, 240, and both maximas all use the same gas cap and all make the same whooshing sound when I open them.
If you have a VG maxima and you don't have a hissing sound when you open the cap than you should!
My 89 vg maxima did not I had a new gas cap and it still didn't hiss when I opened the gas cap!
I then noticed a few dips of gas on the pavment directly uder my left rear wheel suspension, so I thought I had the rusted through gas filler neck but when I go the car home and got under it I saw that the filler neck was intact and infact it was the one foot long 1 inch wide gas vent line that was dripping gas. If gas dripped out of the hose then certinly a pressurized gas could find its way out of the leaking hose.
So I went to the store a got some hose and after lots of swearing got the hose back on and in place and tightend down. Then I poured more gas back into my tank to verify I had stoped the leak and once I saw I had stoped the leak I started the car let it run for a min or two and then I shut it of and removed my gas cap and the hisssssssssssss whooooosssssssss it made the pressure release sound!!!!!!!
Thats most likley most third gens problems!!!!!!!
my 94 & 97 both hiss. the rubber hose and the cap are both good possibilities but also check the filler pipe itself. there is a recall on the 3rd gens for the filler neck rusting out that you guys in the snow belt need to be aware of.
Originally Posted by vansskaterfreek
my 1991 never does that and i just passed inspection in beginning of august (new jersey inspection stations are rediculous)
i have it too...and its totally normal...probly a good thing if the pressure release happens like that. dont forget nissan has recall on fuel filler necks being crappy or something. i cant remember exactly what the recall states but i know its there
ok my gas cap not hissing anymore so i buy new one (non nissan)...now it seems work fine.. the hissing come again but with strange fuel gauge...after driving sometime, the fuel gauge drop half strip. So i try open the fuel cap, theres a lot of hissing and the fuel gauge going up again half strip...any advise whats wrong here?
Maybe something wonky with your fuel gauge sender unit. My cap doesn't make the hissing sound anymore like it did last yr. Not sure if it's because the breather pipe & hose is disconnected all the way to the carbon canister. I know you guys commented on the vent hoses or neck near the filler, but not sure about that other vent hose.
When you open the gas cap with engine running, it will not hiss. But with engine off, it will hiss. Maybe with engine running, the vacuum system (EVAP, PCV, etc) is dealing with extra pressure in the gas tank. Correct me if i`m wrong
05RLS2
Apr 14, 2016 11:49 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
