is this bad??? *pics*
Old Oct 10, 2005 | 12:32 PM
vansskaterfreek's Avatar
i wanted to experiment today (day off) so i pulled some things off to clean......here are pics
http://img.photobucket.com/albums/v2...Picture211.jpg
http://img.photobucket.com/albums/v2...Picture209.jpg
http://img.photobucket.com/albums/v2...Picture210.jpg
is this too dirty????
one other thing, i hear a kind of hissing now that i did this and put it all back together, i am thinking a vacuum leak......all hoses are connected and engine is running pretty rough. any ideas.....the leak seems to be near the oil filler neck...in that area any input appreciated
Old Oct 10, 2005 | 12:36 PM
Greeny's Avatar
¯\(°_o)/¯
Looks likes most 13 yr. old cars with 130,000 miles on them...
Matt93SE's Avatar
STFU n00b!
that's normal for an intake manifold on a 10+yr old car.
mine was like that from my 93 back in about 1999 when I tore it apart. http://blehmco.com/pics/old_max/car/intake_manifold/
yes, you have a vacuum leak somewhere.. look around, you'll find it.
Old Oct 10, 2005 | 01:09 PM
GRNMAXDMON's Avatar
yeah thats normal on ur car. when i took my low mileage motor apart before i dropped it into my '93 it looked just like that. i think i have the pics in my cardomain site on the last page so ur good. just clean it out and u'll be fine. i used carb cleaner and then i just sand blasted all the intake components for my motor and it worked out great.
Old Oct 10, 2005 | 01:19 PM
MrGone's Avatar
CRC Green + Brush = clean
also just do yourself a favor and buy new gaskets along with vacuum hoses.
Old Oct 10, 2005 | 05:56 PM
yes, as i put it all back together, the car runs rough as sh*t now......i can hear air hissing.......the gasket was cracked, so there is my problem..guess i gotta tear it apart again
Old Oct 10, 2005 | 05:57 PM
will cleaning EVERY component in the intake....will it make it run better or faster???? just curious
Edit: sorry for double post
Old Oct 10, 2005 | 10:47 PM
Hectic's Avatar
why are you taking random parts off for experimentation purposes when the car runs perfectly fine? remember, it's your transmission that's the problem..
Old Oct 10, 2005 | 11:25 PM
Loco7's Avatar
any improvemnt it might make in my opinion is not worth the time it would take to make it spotless. but yeah i would clean it up some. just don't spend all day doing it. and make sure it don't fall inside your intake. i did scared the crap out of me thought that my friends little brother threw a nail down the intake. sounded like someone threw a bunch of sand in the cylinders. but it went away 2 seconds later. you know if your going to brake down your engine again why not paint your valve covers while your at it? you pretty much have everything else out of the way. just a thought...
Old Oct 11, 2005 | 04:54 AM
GREGB287's Avatar
i remeber when i was 16 i took my accord engine apart nd couldnt put if back together . so i paid a guy to do it for me and my car ran ****ty ever since
Old Oct 11, 2005 | 05:11 AM
Greeny's Avatar
¯\(°_o)/¯
Vans/Gregb....Quit taking your cars apart for no reason...
Old Oct 11, 2005 | 06:37 AM
DanNY's Avatar
Ad·min·is·tra·tor
a metal nail doesn't just go away...where did it go??
because rattle can paint on a valve cover looks like **** a year later?
Old Oct 11, 2005 | 11:23 AM
DennisMik's Avatar
was the crack in the gasket near a bolt? that would indicate that you are over tightening the bolts which could cause warping of the manifold over time.
Old Oct 11, 2005 | 11:40 AM
ya i know the tranny is the problem, i had a vacuum leak and i thought it was the gasket....and it was
why not, its fun...
it had about 7 cracks
Old Oct 11, 2005 | 04:41 PM
TommyT's Avatar
Hey, that's what my car looked like when I changed the fuel injectors. I thought something must be wrong too.
Old Oct 11, 2005 | 07:19 PM
im gonna give it some new gaskets and a good cleaning.....can i spray throttle body/air tintake cleaner into the holes that go into the motor???? if your not supposed to...oops!!!! LOL what would all the gaskets be called anyone know since pep boys sucks with parts
Old Oct 11, 2005 | 07:20 PM
look closely at the first pic.....
Old Oct 12, 2005 | 07:36 AM
GRNMAXDMON's Avatar
if i remember correctly i think ur just gonna need the intake plenum gasket and the throttle body gasket.
Old Oct 12, 2005 | 04:58 PM
alright, cool thanks, they are what like 5 bucks???
Old Oct 12, 2005 | 05:18 PM
Greeny's Avatar
¯\(°_o)/¯
Try about $50 for the intake gasket....
Remember when i told you to quit taking your car apart for no reason?
Old Oct 12, 2005 | 07:24 PM
dammit, $50 crapola, well it as leaking anyway but $50 dam
Old Oct 12, 2005 | 08:19 PM
Hectic's Avatar
how do you know that's where your leak is? i'm not saying it isn't, but you've said it runs like complete crap now that you've put it back together so it's not even fixed. i still don't understand why you're wasting your time with this... get the car drivable and then worry about a measly air leak.
Old Oct 12, 2005 | 09:20 PM
mordezmoncou
get yourself a bottle of seafoam, and go to town. and a bottle of carb cleaner while you got the manifold off.
has anyone put individual throttle boddies on a maxima before? a vg anyways?
that would be sick
i wonder what kind of numbers you could push out of that?
hmmmmmm
also how long did it take to pull your intake manifold off?
Old Oct 12, 2005 | 11:02 PM
Loco7's Avatar
I didn't say that it was a nail it just sounded like it it was the build up on my injectors. it just worked its was threw the exhaust. the sound went away after 2 - 5 seconds
Old Oct 13, 2005 | 06:01 AM
GRNMAXDMON's Avatar
$50 for just the intake gasket??? damn that thing better talk back to me if i spent that much. the whole intake kit may cost that much i hope. i only paid $2.81 for my plenum gasket.
Old Oct 13, 2005 | 06:09 AM
Greeny's Avatar
¯\(°_o)/¯
This is copied from the autozone site.......
INTAKE MANIFOLD GASKET for a
1991 NISSAN/DATSUN MAXIMA
Normal Stock
Special Order
Not Available
Item Part
No.
Warranty Core
Value Unit
Price Availability
Store Web
FELPRO MS92270-2 $48.99
ROL MS4385 $47.99
BECK_ARNLEY 037-4701 $69.99
CONTAINS PLENUM CHAMBER GASKET 1 PER CAR
BECK_ARNLEY 037-4691 $53.99
PLENUM CHAMBER GASKET NOT INCLUDED 1 PER CAR
Old Oct 13, 2005 | 06:44 AM
GRNMAXDMON's Avatar
Normal Stock
Special Order
Not Available
Item Part
No.
Warranty Core
Value Unit
Price Availability
Store Web
ROL MS4385 $47.99
still too damn much and a rip off for just one gasket.
Old Oct 13, 2005 | 06:04 PM
internetautomar's Avatar
mod or sell?
that's autozone.
people keep saying AZ is cheaper, but every part I've looked at them for is WAY higher than my retail is
Old Oct 13, 2005 | 07:36 PM
GRNMAXDMON's Avatar
that's autozone.
DAMN AutoZone !!!
Old Oct 17, 2005 | 07:39 AM
Matt93SE's Avatar
STFU n00b!
Make sure you're getting the right parts, dude..
the intake manifold has three gaskets.
nissanparts.cc prices:
16175-89E00 Gasket-throttle body $4.51
14032-89E01 Gasket-manifold (lower to collector) $6.86 <------------- this is the one you need.
14035-V5205 Gasket-manifold (lower to head 1993+) $4.88 (2 needed)
14035-V5202 Gasket-manifold (lower to head 89-92) $27.74 (2 needed)
If you're spending more than $10 for one gasket, then you're getting screwed.
I'm goign to guess that if you're buying the fel pro gasket at Vatozone, you're buying the entire upper/lower set, including the pair of $27 gaskets.
Old Oct 17, 2005 | 11:39 AM
im getting my friend to check on the gaskets..he works at autozone and gets discounts he he
Old Oct 17, 2005 | 12:26 PM
max parts's Avatar
looks old really old
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
