Power Locks.
Old Oct 12, 2005 | 08:52 PM
staticlag's Avatar
Power Locks.
My power locks have been out for a few years. They come back on occasionally, most notably when its a really hot day.
The dealership gave some mumbo-jumbo answer last time it was taken in. Anyone else have this problem?
If so, how did you fix the auto-locks, I want to get them fixed, but don't really feel like tearing off panels aimlessly when someone might already have a solution that works.
Am open to all coments and suggestions.
Thanks.
Old Oct 13, 2005 | 12:32 AM
Loco7's Avatar
my power locks work sometime than they quit regardless of weather. with mine if i take the lower dash panel below the steering wheel and mess with the connection at the lock module it comes back on (for a while) if i hit the lock button (or is it the unlock button, only one works) i can hear the module click but does not unlock the doors or lock them for that matter. when it does work if i hit the button it locks if i double tap it it unlocks. once in a while when the car get mad it locks the doors by it's self regardless if the doors open or closed, car running or off. I finally completely removed the locking system from the doors. so none of my doors have locks. of course they also don't have door handles either.
BUT my piont was it's my module. use a light tester or preferable a multimeter and check to see if there is a current comeing to and from the module. if you have current coming to it but not out when you hit the switch it's the module. if there is a current to and from than you know you have a bad connection somewhere in the system. of course you might have a bad switch if you have no signal to the module. just to let you know even if 1 or 2 actuators go out the other 2 should work. Also not trying to be a smart a** but check the fuse first. sometimes it's the smallest things that give me the most crap!!
A little help also is the module under the dash is to the right of the steering column.
the wire for locking the doors is gray/red. it's a negitive connection.
the wire for unlocking is light blue. it's a negitive conection too.
as far as the rest i have no clue!
Old Oct 13, 2005 | 02:01 AM
Greeny's Avatar
Ż\(°_o)/Ż
Thanks.
You need to replace the door lock timer.....It is to the right of the steering wheel...I have a used one if you want it...
Old Oct 13, 2005 | 06:50 AM
bhunter's Avatar
Read the stickies. It is VERY easy to fix the door lock timer. Basically remove it and resolder around the area of the relay on the board. Use magnification and inspect the board for solder joints that have cracks in them and solder them too. Many here have fixed theirs doing this.
Old Oct 13, 2005 | 10:21 AM
staticlag's Avatar
Excellent!
I glad I didn't just start tearing things apart.
Old Oct 13, 2005 | 10:18 PM
fatboyslim86440's Avatar
my locks have been out for years i resoldered the timer and it still didnt work try moving your harness around while pushing the unlock botton i had to ziptie my harness up soo they work
Kyle Cisneros
Old Oct 14, 2005 | 12:23 AM
Loco7's Avatar
Kyle Cisneros
Sound like my headache i had. never thought of zip ties. Oh well i completly removed that option. Now i just have to figure out what to do with the lock switch. Any ideas? I just need something to do with it. If i have to have the switch it might as well have a function!
Old Oct 14, 2005 | 01:51 AM
Wiking's Avatar
Originally Posted by Loco7
...as far as the rest i have no clue!
Why? Dont like schematics? Check my CDomain site - Favorite Links (at left)... and/or p.13 http://www.cardomain.com/ride/748507/1
Zipties have no electrical properties and cannot 'cure' the lock. If problem cause is loose connectors [intermittent], first correct the problem, connectors. The wires have surely to be tied as they once have been.
"what to do with the lock switch. Any ideas?"
- pls explain the current situation. The lock/sw/mechanism is there... or is not?
Old Oct 14, 2005 | 01:59 AM
Wiking's Avatar
... The dealership gave some mumbo-jumbo answer last time it was taken in. Anyone else have this problem?...
Lol. Last time I heard that mumbo, was some 20yrs ago I was forced to listen and promised to sue them ... all is well now: never will visit stealer$hip service dpt. (On few unlucky days, have to go spares s hoppin.)
Old Oct 14, 2005 | 05:14 PM
staticlag's Avatar
Wow, my locks haven't worked in 5 years, but they do now!!!
Re-soldered the two connections.
Old Oct 15, 2005 | 03:50 AM
Loco7's Avatar
- pls explain the current situation. The lock/sw/mechanism is there... or is not?[/
never said zip ties would fix it just said never tried that before. because if i held it in a certain spot it would work.
the lock mechanism is gone but the switch is still there. just ahven't thought of what i want it to activate.
Old Oct 15, 2005 | 07:24 AM
Wiking's Avatar
never said zip ties ...the lock mechanism is gone ...
No, u did not. I just wanted to underline the fatboys msg, that there is a real problem which should be addressed. Either connector, or broken wire... problem in waiting ...for moist?
U jump in via sunroof?
Old Oct 16, 2005 | 12:46 AM
Loco7's Avatar
no i installed acuators hence fourth no need for locks. as fars as fatboyslim86440 no crap it should be addressed but since i have always planned on shaving the door handles off i wasn't too worried about it
Old Oct 16, 2005 | 02:57 AM
Wiking's Avatar
no i installed acuators ...
One day, a writeup with pics, please?
Old Oct 17, 2005 | 01:41 AM
Loco7's Avatar
as soon as i can figure out how the HELL to post pictures without uploading them to a web site. sure. Now i just need to buy a digital camera
Old Oct 17, 2005 | 01:51 AM
Wiking's Avatar
Each time a discussionthread opens, pics are loaded from where ever they are sittin. If u set up your pc as a server, all 'million ppl' looking at a certain thread will be each sucking u complicator for that one pic. Want THAT?
Then comes the day that u have written 1000 threads with few pics here and tHere. Multiply that traffick, all on/off from your computer. JammEd feelin?
Old Oct 17, 2005 | 02:50 PM
ejoy1220's Avatar
On the topic of powerlocks, can anyone tell me why, when I lock my car and close the door, the power locks unlock? I have to close the front door, open the rear driver's side door, and push driver's side door lock down and close the rear door to lock the car.
Old Oct 17, 2005 | 05:49 PM
xnyc's Avatar
probably a prevention method like if your filling up and your doors are locked and you close the door with keys inside. doors will become unlocked.
Old Oct 17, 2005 | 07:28 PM
ejoy1220's Avatar
Yeah its like a safety proceedure so you dont lock the keys in the car, but the keys aren't in the car. Is there a switch somewhere that senses this?
Old Oct 18, 2005 | 01:13 AM
Wiking's Avatar
Originally Posted by ejoy1220
... Is there ... somewhere ...
See if, click on LINKS. Up tHere some where ↑↑↑↑↑↑↑↑↑↑↑
Old Oct 18, 2005 | 02:48 AM
Loco7's Avatar
good piont! besides my computer REALLY sucks
Old Oct 18, 2005 | 06:42 AM
Wiking's Avatar
What sucks is Microsoft AND Internet Explorer. Download free Mozilla Firefox.
IE stores 'all' cookies whatever u get from surfing. Change ie options settings, temp internet Files storage are to minimum 1Mb. These files 'demand service', u computer spends its time serving these. Delete all temporary files, easily there could be tens of thousands. Idiots: They are stored at least TWICE below 'documents and settings' & 'windows' subfolders...
Or format your HD, reinstall win-dowser and never touch IE. Buy more memory; after ˝GB you may take out the windows swap file and be free of its most repulsive disk fragmenting feature working havoc on u files...
Dont be afraid of viruses - win dowser is biggest!
Old Oct 18, 2005 | 06:57 AM
bhunter's Avatar
Your car may require that you hold the handle up while shutting the door. Some of the older ones did that.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
