To those who have done the 5-speed swap...
Old Oct 1, 2006 | 11:55 AM
  #41
GRNMAXDMON's Avatar
Originally Posted by 2Legal4Me
no!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1 unless you are going to pull the entire engine an trans out to swap out the f20 wiring harness in replace of th f21 wiring harness my remark not really necessary. i have personally done the rewire from the f20 harness and just cut and spliced it onto the the f21 5speed connector (4 prong connector). i will post the link for this conversion shortly in which i used to complete my max.
the info on completin the wirin' for the F20 and F21 harness's is at the beginin' of this thread and its also in the stickies as well. about the pilot bearin' i didn't install that on my max cuz no one told me about that but it hasn't given me any problems for the past 2yrs since i've done the swap. either way i have a spare tranny layin' around just in case but it was good that u brought this up.
Old Oct 1, 2006 | 11:57 AM
  #42
GRNMAXDMON's Avatar
Originally Posted by Jbr8k
Tranny computer-tcu
the 5-speed tranny does not require a tranny computer at all. u can leave the auto tranny computer in the car since its not gonna be used anymore. so don't worry about that. ECU stays the same by the way. no need to swap ECU's from auto the manual. it will work the same.
Old Oct 1, 2006 | 10:17 PM
  #43
2Legal4Me's Avatar
yea so just cut into the f20 harness with the write up from GRNMAXDMON and go from there real easy. i had hooked up the gear selector starter / reverse switch also into the f20 harness because i have a 2way pager w/remote start and did want my car to be in gear if i attempted to start it. and as for that i got cruise control and reverse lights and start disable if in any gear. i had also wired my cluch pedel into my brake pedel to disable the cruise control with the clutch pedel.
niZ
Aug 7, 2015 10:18 PM
jdonavich
Feb 6, 2001 08:25 PM
ArcticMax
Jan 5, 2001 01:37 PM
jsmiam
Dec 16, 2000 11:43 AM
ArcticMax
Dec 10, 2000 11:19 AM
