Gas smell from the tank cover
Old Oct 13, 2005 | 09:07 PM
Maxpwer's Avatar
No turbo, no care!
Ever since I changed my fuel pump to a walbro 255, I have had a gas smell from the tank cover (under the rear seat). Oddly, during the summer the smell was hardly noticeable unless you opened the trunk. Now that the weather is cooling down its starting to smell again and I cant put up with another winter sucking gas fumes (especialy with the cost of gas these days)
I have tried to reseal the cover with every different type of sealant I could think of with no luck. Does anyone have a solution or encountered this problem before?
Old Oct 14, 2005 | 02:58 AM
Greeny's Avatar
¯\(°_o)/¯
It's possible the fuel lines connecting to the cover are leaking....
Check for leaks from them with engine running.....
If no leaks there then try a new rubber seal on the cover.....
Old Oct 14, 2005 | 04:39 AM
Wiking's Avatar
Originally Posted by Maxpwer
...or encountered this problem before?
- fumes cost as much as dollar aromas
- sealing wrong hole gives wrong results
- howabout rust recall?
Old Oct 14, 2005 | 08:17 AM
DennisMik's Avatar
if you can smell gas, you have a leak. hiding the problem so you can't smell it isn't good. if you didn't replace the rubber hoses when you changed the fuel pump, that is probably the cause. they are old and brittle and have probably developed a crack.
mclasser
22
Nov 12, 2020 01:58 PM
mkaresh
Mar 12, 2018 06:48 PM
Fbana41
Aug 29, 2016 12:18 PM
carid
Sep 17, 2015 05:00 AM
