How can I be sure my Max is being cooled properly?
I finished changing my radiator, coolant, and Coolant temp sensor this week. I was running the car for about a hour today and the fan never came on. The temp guage seems to stay at a little below half. Every now and then, it will shoot all the way to the top, something its done since I bought it and then come back to normal. Is there anyway to check that the fans are working correctly. I was thinking one the relays may be bad but Im unsure of how to check them. Any help is appreciated so please chime in!
You need to bleed the cooling system of air pockets..That is what is causing the jump in the temp gauge...When a pocket of air passes by the the temp sensor,it is much hotter then the coolant=the needle jumping up quickly....
Do you have a ve or vg??
Here are some past thread links on the bleeding procedure...
http://forums.maxima.org/showthread....ystem+bleeding
Had air in the coolant system.......
hit your a/c and see if they come on. these cars keep cool easially. my fans rarely have to kick in, and when they do, it's for 5-8 seconds. it'll take a few bleeds. make sure you keep coolant in the overfill tank so you're not sucking in more air. there could be big pockets in there that will suck it dry.
Originally Posted by jigga123
... Any thoughts about the fans?
2. unplug fan connector(s), give direct +12V
3. sink ECU pin6 & pin19 down (with a 390ohm or whatever grounded resistor)
Air bleed: one hour drive 2000rpm or over, with some hose bleeding a little. Keep reservoir at max mark.
For Details See http://www.cardomain.com/ride/748507/1 see p.7& p.8
Originally Posted by Wiking
1. Test: take EGRC temp sensor connector off: High idle, 1500rpm, both fans maximum, warm engine.
...I cant count the number of tiumes u saved my butt.
edit: btw, here the compressor clutch is also energized and AC compressor starts to produce cool. (Engine idling).
Hey I noticed that he mentioned that his temp is usually slightly below half..mine is always like 1 or 2 little lines above half, I have a new waterpump and thermostat is my car temp normal now that he brought that up?
Originally Posted by ColombianMax
...mine is always like 1 or 2 little lines above half,...
What is normal? As long as heater pushes real hot, engine does not boil over, accept the needle pos - if it behaves similarly each day.
My tgauge needle goes to halfway. At my modded kickdown drops to zer
Originally Posted by Governor
Mine has always done this and I have bled system...it is simply a bad guage..one bang on the dash and its back to normal..
