weird heater problem
Old Oct 25, 2005 | 09:07 PM
Krannick's Avatar
since it snowed here in quebec tonight, i ran the w-defrost on full heat...
left side of the dash, heat, but nothing like it is supposed to be
right side of the dash....very cold air...., it did it on all the positions i can get air out.....(top, front, bottom, auto, econ, manually adjusting fan speed)
anyone got an idea as to what the .... is going on??
got a 1992 gxe with auto climate control
Old Oct 25, 2005 | 09:46 PM
DennisMik's Avatar
verify that the engine coolant is filled all the way and the heater core has water flowing through it. from what you have said, i kinda think that you are having a problem with the doors inside the ducts allowing cold air in and not shutting. maybe a link fell off or broke.
Old Oct 25, 2005 | 09:53 PM
Harvs94max's Avatar
it sounds like to me your fresh air door is stuck open
to verify is the fresh air switch real easy to move up and down if it dosnt give resistance than the cable might have snapped off the plastic on your climate control unit
Old Oct 25, 2005 | 10:35 PM
Wiking's Avatar
Originally Posted by Krannick
...auto climate control...
box is like this, see http://www.cardomain.com/ride/748507/7
...see craigs page for auto
Old Oct 26, 2005 | 07:30 AM
Krannick's Avatar
mine got an electronic display where you choose the temp is .5 celcius increments
coolant liquid is full and bled properly....got heat on the left only
will i have to take the full dash appart to get to the "door" which stands open???
Old Oct 26, 2005 | 07:39 AM
Wiking's Avatar
Lots ppl HERE have opened their heaters, but no pics. less writeup. Hi time smbdy helped this forum...
As said, chk craigs page. GO See favorite links -at my CDomain site.
There has to be actuating motor. Maybe wire loose, gears screwed?
I'd cut a 1" hole to see in, tape/glue it closed.
Old Oct 27, 2005 | 10:25 AM
MaximamixaM's Avatar
FWIW my 94 gxe auto climate control did the same when it was low on radiator coolant, but your coolant level sounds good...
Old Oct 27, 2005 | 02:52 PM
Krannick's Avatar
...i was kinda dumb.....the only reason i post it is to stop others of making the same stupid mistake......
the "fresh air" **** was ON....so cold air got in the car by the right vents...
by turning it off, i get hot air on both sides (hotter on driver side)
which means that i MAY really have something stuck somewhere in the duct...
Old Oct 28, 2005 | 03:00 AM
Wiking's Avatar
...the "fresh air" **** was ON....so cold air got in the car by the right vents...
Right wrong or left closed, wassup?
The fresh vent is an option [US std]. **** is missing in My vehicle. FSM explains it: "allows fresh air from MID vents - as other vents produce simultaneously hot air."
My MID vents (if vent flap open) always produce fresh air.
Old Oct 28, 2005 | 07:05 AM
DennisMik's Avatar
on my max, if i open the fresh air vent, i get the same exact un-even temperature from the air outlets that krannic had. nature of the beast, i guess.
Old Oct 28, 2005 | 07:48 AM
Tarzan's Avatar
If I flip the fresh air lever, I get cold air from both middle vents and the rest depends on the setting of the auto climate.
Old Oct 28, 2005 | 12:59 PM
Krannick's Avatar
ok...so my only problem is with my right-most vent....ill look into it this weekend....maybe a few pics and a how-to will follow
AaronL
Nov 15, 2020 11:52 AM
05RLS2
Sep 27, 2015 09:24 PM
yamehoo
Sep 24, 2015 10:21 AM
RWCreative
Sep 21, 2015 11:01 AM
bennuss
Sep 11, 2015 05:55 AM
