what size tires for 18'' wheels
Old Oct 27, 2005 | 08:07 AM
tobe2be's Avatar
I got a 91 maxima with eibach pro kits and kyb struts. i am looking for a set of 18'' wheels but im not sure what tire i will need to use in order to clear rubbing. thanks in advance for your help. if your selling a set of 18's let me know thnkas
Old Oct 27, 2005 | 10:02 AM
Mizeree_X's Avatar
Getting back to his roots
There is a "wheels and tires" forum that you can check but I'll help you out.
A. Clearance is highly dependent on the offset of the wheels. (+30-35 is a good range to look for).
B. 235/40/18 is the ideal size for an 18" wheel, but depending on clearance issues you may have to run a 225/40/18 to get them to fit in the rear.
Hope that helps.
Old Oct 27, 2005 | 10:27 AM
aw89maxSE's Avatar
might need some wheel spacers if you're running 235/40/18
Old Oct 27, 2005 | 03:52 PM
CyMax's Avatar
Dont know exact size but I bet you can find out on www.tirerack.com
Old Oct 28, 2005 | 05:09 AM
tripleGmax's Avatar
thats why miz said you might need 225/40/18 in the back.
im running 235/40/18 all around offset +30 and no spacers,
Old Oct 28, 2005 | 10:03 PM
tobe2be's Avatar
now is this with an eibach drop or on stock ride height? just wanted to make sure thanks in advance fellas
Old Oct 29, 2005 | 07:05 AM
tripleGmax's Avatar
dropped or not the tire size doesnt change.
Old Oct 29, 2005 | 12:16 PM
Cliff Clavin's Avatar
Way out West
It depends on the offset -- how close it is to the rear strut.
Old Oct 29, 2005 | 11:09 PM
Maxzilla91's Avatar
just to keep with the tradition here.
if you have to ask, you have no bussiness attempting it. LMAO....
Old Oct 30, 2005 | 09:39 PM
mtrain's Avatar
I am running 235/40-18's on my 89 and the rears clear fine, its the front right that rubs when I turn all the way to the left. I got some spacers on order....
Old Oct 31, 2005 | 04:32 AM
tripleGmax's Avatar
that car is hawt dude. nice work
Old Oct 31, 2005 | 05:55 PM
mtrain's Avatar
If you're talking about my car then thanks! I still got some work to do, though. Next paycheck i am replacing the lower control arms and tie rod ends. She's a little squirrelly right now.
micah
Old Oct 31, 2005 | 08:41 PM
Alex_V
18s are to you like shiny things are to rednecks
Nice car, really. My first max was that color.
~Alex
Old Oct 31, 2005 | 09:27 PM
tripleGmax's Avatar
Alex, you better be carefule or i wont sell you these 17s.....
Old Oct 31, 2005 | 09:30 PM
kcidmil's Avatar
he does have a point gregg....
Old Oct 31, 2005 | 09:32 PM
tripleGmax's Avatar
screw you ben
Old Oct 31, 2005 | 09:34 PM
kcidmil's Avatar
No thanks... I have a wife to do that
I'm surprised you bothered with 18"s... with all those pot holes around, it's amazing you still have rims
Old Oct 31, 2005 | 09:44 PM
tripleGmax's Avatar
na everything is great around here.....of course potholes suck, but i wear a neckbrace when i drive...
Old Oct 31, 2005 | 09:45 PM
tripleGmax's Avatar
micah
but of course!
Old Nov 22, 2005 | 08:30 PM
tobe2be's Avatar
well im considering purchasing g35 sedan 18'' wheels but those are +45 offset. just wondering if they will work with 225 40's. thanks in advance
Old Nov 22, 2005 | 08:35 PM
pitchedup's Avatar
you should stretch your tires like this:
with a good fitment, I bet it would look good on a max.
Old Nov 23, 2005 | 03:58 AM
tripleGmax's Avatar
we should stretch our tires? why so we can drift our maxima? or so we can curb our wheels? that just doesnt seem to be a great idea on our cars.
im not sure if they will fit. they are 7.5 inches wide with a 45 offset...hmm not sure
Old Nov 23, 2005 | 09:33 AM
Jeff92se's Avatar
I'm needing a caw
I can't see how that DOESN'T rub. Look at that stupid camber. Nothing like idiot camber to take 2/3 of the tire's life.
Old Nov 23, 2005 | 09:45 AM
Jeff92se's Avatar
I'm needing a caw
Hmm I've run 18x8 with 30mm offsets with up to a 245. 245-225=20mm or 2 cm. divide that 1cm = 0.40"
Now you want to run a 45mm offset vs what I ran (30mm) 45-30=15 or 1.5cm = 0.60". so these wheels will tuck more by 0.60"
So the question is. Is there an extra 0.20"? So I'll say "yes". But that's only my educated guess on the matter.
Also a 225-45-18 is a few % bigger in dia vs stock. No biggie.
Old Nov 23, 2005 | 09:47 AM
pitchedup's Avatar
why not stretch your tires? I think they look good. Why would having stretch tires make our cars into a drift car. A lot of people in the volkswagen crowd have stretch tires, does that mean they drift also?
Old Nov 23, 2005 | 09:48 AM
pitchedup's Avatar
that car is bagged...hit the switch and raise it up
Old Nov 23, 2005 | 09:49 AM
Jeff92se's Avatar
I'm needing a caw
Installing tires onto wheels that are beyond the recommended width specification is unsafe and unwise. Not to mention stupid in general.
Although that pic doesn't look too bad.
Old Nov 23, 2005 | 09:56 AM
pitchedup's Avatar
Yea; there is a safety issue. Having stretch tires seems to be mainly aesthetic.
Old Nov 23, 2005 | 10:11 AM
Tarzan's Avatar
Nice hubcaps!
Old Nov 24, 2005 | 12:45 PM
Loco7's Avatar
To be honest streaching the tire can look good on a car but is Very unpractical and of course a matter of opinion on how good it looks. I have a friend with 13" on a S10 with switches and his camber all messed up. He only drives it on the weekends but even with that little use his tires are shredding as fast as he can replace them. But to each there own.
Like MTrain I had 17 on it and when i turned all the way left it would rub. Put my stockers back on still does it. Of course my car is pretty low!
BkGreen97
Apr 2, 2016 05:47 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
minsbang
Sep 11, 2015 08:48 PM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
