help with y-pipe studs
Old Oct 29, 2005 | 02:32 PM
vansskaterfreek's Avatar
i was when i switched my y-pipe studs, i broke a couple, how do i get them outta there?????
Old Oct 29, 2005 | 03:30 PM
Greeny's Avatar
¯\(°_o)/¯
You are going to have to drill and easy out the remaining pieces of studs that is still in there..Good luck with that..[PITA]
You might want find some used manifolds to put on there....
Old Oct 29, 2005 | 08:21 PM
disgruntled's Avatar
or mill them straight, give your engine a good cleaning up while you're in there. Oh, take lots of pictures too, we need a good pictorial how to. Good luck.
Old Oct 29, 2005 | 10:19 PM
TommyT's Avatar
Man, I'm glad I didn't have this problem when I replaced my Y pipe. Guess I was lucky.
Old Oct 30, 2005 | 07:58 AM
the thing is that when i replaced my y-pipe, they didnt break...i had the studs, but i forgot about them...now i tried to get them off, and they broke!!!!
Old Oct 30, 2005 | 07:30 PM
Dillbag's Avatar
Suprise butsechs!!!
cut the studs flat against the flange. then just drill them out (make holes where the studs were). then just use a longer bolt and a nut. that will clamp the y-pipe to the exhaust manifold just fine. it's a tad shadetree, but it works just as well.
Old Oct 30, 2005 | 07:49 PM
Alex_V
I did the same. I thought my dad did all 3 in the back but he only did 2, and its leaking like a mother, so I have to do the third. And 1 in the front, but the front isnt leaking so I can do that later... but yea a nut and bot works great. But using PB blaster in the first place is the best.
~Alex
Quickywd01
Sep 21, 2016 09:36 PM
dcam0326
Sep 26, 2015 05:20 AM
lrb6805
Sep 17, 2015 04:49 PM
Violator
Sep 9, 2015 10:14 AM
