Valve rattling in a vg question. also gas grade question too.
Old Nov 1, 2005 | 08:16 PM
mordezmoncou
I have an 89 se 5spd with 141k miles, runs strong, hella fast. Intake, and 2.25inch custom mandrel bent catback with an hks dragger muffler
nothing special.
Well
in the mornings, and when my ac is on, or if it hasent been ran for a while or fully warmed up. My vales rattle, and I hear it worse when its cold outside when it first starts up and as im driving, it only does it when im driving or rev it.
Whats the deal? Do i need new valves? Valve job? What do you suggest as a fix to this.
Also i ONLY run mid grade gas in my car. Ever since ive ownd it, it has never seen regular, im sure the previous owner might have, but then again im not sure. Ive only had it for 2 months ish.
Whats best to run in a vg max in my shoes. regular, mid, or premium ?
alll suggestions welcomed.
The motor wont be in much longer, in about 4 months ill be hopefully doing an sr20det fwd swap or an RB swap.
Old Nov 1, 2005 | 09:36 PM
Dillbag's Avatar
Suprise butsechs!!!
SR20 swap i could see, but RB???
Rattle could be in the a/c compresor, but maybe carbon in chambers? try injector cleaner in tank? or could be lower end engine noise. need to have a pro give a listen maybe.
tune-up? timing? plug wires? Just brainstorming, noises like that are best listened to in person to diagnose.
Old Nov 1, 2005 | 09:46 PM
mordezmoncou
well, even when the ac is not on it does it lol.
but after its warm the baby purrs like a tiger.
im not sure how old the plugs and wires are, the wires look very new, every hose on the car is new. the guy i got it from worked at a dealership and and it was in tip top shape.
its not bad when it does it, just does it while its cold mainly or the ac is on. But it goes away when warm.
im thinking of seafoaming the car, pouring some in the vaccum line, and then doin it in the gas tank and in the crankcase right before an oil change.
Old Nov 2, 2005 | 02:42 AM
Tom's Avatar
Tom
Check your exhaust manifold studs. You may have some that are broken. Some of them are hard to see so when the engine is cold, feel around for them.
Old Nov 2, 2005 | 06:45 AM
Tarzan's Avatar
Valve rattle, hmm... You mean, they do clicky-clicky-click? That's the hydrolifts failing to expand fully, it's a cosmetic issue that you can ignore, unless you want to spend a few hundred bucks. If you do, however, you can get lots of other things done as well.
Old Nov 2, 2005 | 07:15 AM
DanNY's Avatar
Ad·min·is·tra·tor
SR20DET....
you're going to swap OUT a V6 and swap IN a I4? I thought the process of an engine swap is to GAIN more power. You're losing a full 1 liter of displacement in the engine.
If you're going to be FOS at least talk like you know what's going on.
your problem...like someone mentioned..it's either hyd valve lifters not sealing anymore or the exhaust manifold studs.
Old Nov 2, 2005 | 08:28 AM
mordezmoncou
i said sr20det, i didnt say it was goin to be a stock sr20det did i?
lol
There is a guy around here who has an RB swapped max, and an sr20det max. very very cleanly done and alos insanely quick.
Old Nov 2, 2005 | 08:35 AM
yandianj's Avatar
Can you get some pics of the RB guy and post them? I would like to see that. Did he do a RWD conversion also......
Old Nov 2, 2005 | 08:42 AM
mordezmoncou
next time im up in his area i can.
Old Nov 2, 2005 | 09:08 AM
DanNY's Avatar
Ad·min·is·tra·tor
lol
ok so you mod the SR20DET...then what? you think that'll just bolt right in w/o problems on a 3rd gen?
show me something (pics?) before you continue this discussion.
Old Nov 2, 2005 | 11:30 AM
Alex_V
forget the SR I wanna know how a RB will fit with FWD. Unless your talking about a 1st gen (only RWD max) or a rwd converted 3rd gen.
~Alex
Old Nov 2, 2005 | 03:29 PM
mordezmoncou
i never said it would be an easy swap, it takes lots of money, time and fabrication and converting.
but im goin to be orginal and do it, anything is possible.
Old Nov 2, 2005 | 06:39 PM
tripleGmax's Avatar
how can you be original if its already been done? danny throw up that bs flag again.
Old Nov 2, 2005 | 06:40 PM
Maxpwer's Avatar
No turbo, no care!
If someone else has done it, you wouldnt be original (orginal) would you? Why not do a 454 with a blower (sticking out of the hood), it would be cheaper, original and make more power.
Old Nov 2, 2005 | 09:11 PM
Dillbag's Avatar
Suprise butsechs!!!
I thought we were talking about rattles? not FWD 454's.
mordezmoncou
claim bs all you want lol.
I could care less wether you belive me or not.
But end of story the sr20det will be original, but not the first ever done. there has been a few. I even found one on google of a guy starting the project and getting 80% done, had wireing issues on the last page, and said more updates soon, never updated it. This was over a year ago. I tried to go to the link, but the link doesent work. Google it. If people can take an RSX type S motor (k-series) and put it in a civic hatchback or a crx, then why cant you belive fwd sr20's can go in max?
People take h22a prelude motor, and cram those huge turds into crx's. ive even seen a guy take a 350 and put it in a CRX. google it.
if you know what your doing, and have an imagination, patientce! and the right conections, almost anything is possible.
I understand you doughting it, because you have probably never seen it or thought about it. Im not one to thrash on anyone, but motor swaps are not a taboo like some people think. They are done day in and day out, some of the craziest swaps have been done and I probably dont even know about them. From some of the things ive seen at friends shops, I can say, if you have the money, and the imagination, it can be done lol. Enough said.
Old Nov 2, 2005 | 09:22 PM
DanNY's Avatar
Ad·min·is·tra·tor
check your registration...we don't drive hondas.
you seen anyone swap out the V6 motor from the accord to put a I4 motor in? if you can't get past the simple theory of english spelling and engine displacement->power then you shouldn't talk about swapping anything
Old Nov 3, 2005 | 03:56 AM
mordezmoncou
Ive seen a v6 accord that put an rsx k series swap in.
Old Nov 3, 2005 | 04:20 AM
Greeny's Avatar
¯\(°_o)/¯
Dude...Why don't you just go buy a honda then...
Putting a 4 banger into a nissan v6 platform car is just stupid....
Yeah you have seen all these crazy motor swaps in other cars,but these swaps takes many$$,knowledge, and many hours of your time to do...
Yet you do not know why your car is rattling at startup...
Old Nov 3, 2005 | 08:28 AM
Kikcaffine's Avatar
He's had hondas, many of them infact. Dont butcher a maxima, just because you want to be different. Swap in a vq35 like that one guy in cali did. That would be a good swap. an sr20 would not be.
Old Nov 3, 2005 | 08:59 AM
DanNY's Avatar
Ad·min·is·tra·tor
that owner is a moron then. why would someone take the J30A with more torque (unheard of with 4cyl motors) swap in a smaller K20A?
i'm talking about 98+ accords here...6th gen (i think)?
Old Nov 3, 2005 | 10:08 AM
mordezmoncou
this isnt my first max lol.
btw, I can do what I want, why does it matter what I do to it? And plus if i do an sr20det swap, its not goin to be jus a little 4 banger.
Btw honda sucks. I can say that being ownd more then a few.
As far as in comparison with my vg30e and an SR20det, there is alot more things I can do with the sr then the vg, also interms of easy to upgrade, and also easy to acess things. the vg's are hard to get things for and not alot of people make upgrades for the vg.
I know you thinking why downgrade form a v6 to a 4cyl, but if you saw what I saw when i rode in this guys sr swapped max, you would understand.
He had alot done to it, and it was quicker then a boosted vg, or even a boosted ve, he has lots of time and money into it, and it took him a good while to get to that, but thats what im doin, no reason to rag on me for wanting to start a project and making something my own. at least im doing something diff, not something that you can always find in a maxima like a vg or a ve, as far as the vq
vq's are really expensive and hard to get ahold of. IM working with what I have and doing what makes me happy. dont ragg on what i do, worry about your own.
Old Nov 3, 2005 | 10:53 AM
Greeny's Avatar
¯\(°_o)/¯
This statment proves beyond a shadow of a doubt that you have no idea what you are talking about....
Old Nov 3, 2005 | 11:12 AM
DanNY's Avatar
Ad·min·is·tra·tor
1 - DO THE SWAP
2 - TAKE PICS
3 - POST
4 - THE WIN
you have 4 months...so figure ummm mid march i'll see a ton of pics from you on your SR20 swap...right? don't forget to get the digicam NOW so there will be NO excuses. the cheapest ones are around 100 bucks and it takes ok pics.
FYI: VQ motors are a dime a dozen. nissan used the VQ block in virtually every V6 platform since they introduced the VQ.
from this point forward whatever you say about this SR/RB swap in your car is total BS until you show me otherwise.
oh and by the way...i would love to see your friend's SR swap into his maxima. oh wait...no camera yet right? you think you're the first n00b that claims to do a swap in the near future?
mvm062
Nov 30, 2020 09:00 AM
kingw323
20
Oct 21, 2015 08:36 AM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
