Which is the best air filter to use?
Old Nov 7, 2005 | 12:38 AM
dragon6473's Avatar
I also plan to change the old Fram air filter that I have on now and I don't know what to get as I don't plan to get another Fram..any suggestions?
Thanks. Btw, I got Mobil 1 at Costco today for my oil change soon..what to see if there's any difference from Castrol.
Old Nov 7, 2005 | 01:39 AM
Greeny's Avatar
¯\(°_o)/¯
If you are not looking for performance then any of the panel filters will do fine...
Old Nov 7, 2005 | 02:33 AM
Wiking's Avatar
Lots of contradicting issues:
- air flow restriction
- capability to catch harmful particles
- filter material brittleness
- how fast gets blocked
...so what do u want???
My feelin was that Fram was superior to Nissan -filter. Engine gets more air, and VG is very sensitive. Is Fram then better if it lets more soot through??? (Does it?)
It is said that bad filter material gets loose and burns into MAF resistors, cause of failure. Could be, who can verify if this is urban legend...
Overall, Filterin is Fairly complicated multifaced issue if one tries to dive into micron fact level, beyond feelins...
Old Nov 7, 2005 | 04:15 AM
lp's Avatar
lp
Nissan paper panel.
K&N panel in my VG/Auto caused random dips in the idle for some reason.
Car had three other intakes on it over the years, PR CAI, Pop and Unifilter Rampod. None of those affected idle at all, only the K&N panel in the stock airbox. Put it in, idle would fluctuate slightly, take it out, idle was rock solid. Funked if I know why.
Old Nov 7, 2005 | 02:47 PM
Seb181's Avatar
Hey I Just bought a 1990 maxima SE for $400 (150,000 miles) and would like to put money into it performance wise....I was thinking Exhust and intake first??? any suggestions? Also what intake should I buy is the one on ebay for the Honda's a good start? Help this newbie out thanks
Old Nov 7, 2005 | 03:40 PM
CyMax's Avatar
Tons of info in the stickies at the top of the forum main page,but.... y-pipe, flywheel/clutch, UDP. I havent really heard too much about a CAI or WAI making too much of a differance.
Old Nov 7, 2005 | 08:28 PM
Dillbag's Avatar
Suprise butsechs!!!
A clean one.
Old Nov 7, 2005 | 08:54 PM
maxitech's Avatar
K&N works for me!
Old Nov 7, 2005 | 09:53 PM
MrGone's Avatar
based on my experience with Fram oil filters, I'd rather just not buy anything Fram at all.
If you want to stay stock go Nissan. Amsoil has a new element filter out that is supposed to be pretty nice. Napa Gold's aren't bad either.
Old Nov 7, 2005 | 10:03 PM
AscendantMax's Avatar
K&N for me. no problems what-so-ever.
Old Nov 8, 2005 | 02:24 AM
Wiking's Avatar
... Exhust and intake first??? ...
Money doesnt hlp. VG needs more air: http://www.cardomain.com/ride/748507/2
Old Nov 8, 2005 | 05:53 AM
Tarzan's Avatar
Nissan stock air filter is the way to go. Performs much better and much longer, than crappy aftermarket. I know nothing of the cone filters though...
Old Nov 9, 2005 | 09:59 AM
Dillbag's Avatar
Suprise butsechs!!!
Like I said, anything clean and not clogged-up, just inspect with every oil change. I hope everybody is doing that, every oil change give the car a look over, helps spot stuff before it becomes a problem. Most shops/dealerships/jerky-lubes do that for you, if you have someone else change the oil.
Old Nov 9, 2005 | 12:02 PM
MrGone's Avatar
It's surprising how many people don't give their cars a once over while they change the oil.
I normally drain it then do all my inspection work while it's draining. If it's still draining I just start cleaning . I am way too thorough with my cars but hey, that's not a bad trait
People would be surprised with some of the stuff that can happen in 3000 miles.
Old Nov 9, 2005 | 01:03 PM
Hemphire's Avatar
Nah forget all that just make one outa cardboard and paper towels.
Old Nov 9, 2005 | 02:11 PM
internetautomar's Avatar
mod or sell?
it's a toilet paper roll for an oil filter. and a shop rag for an air filter
Old Nov 9, 2005 | 08:50 PM
Dillbag's Avatar
Suprise butsechs!!!
or pantyhoes on the end of an intake tube, cuz your cone filter fell off. (my buddy's car)
Old Nov 10, 2005 | 02:19 AM
Wiking's Avatar
Originally Posted by Tarzan
... crappy aftermarket. ...
As said, filter has myriad aspects to fulfil.
- dry structure properties
- moist & wet structure properties
- seals, glue, rigidity, emission (fiber brittleness) etc properties
- Airflow - new
- Airflow - used
- Capability to catch harmful particles to engine
- what else?
After market: Nissan does not mfg its own filters but buys all accoring Nissan set requirements & nissan logo. There is handful filter mfg's in the world, and surely some of their products are crap. Generally i'd boycott chIraq's products, but here I go Franco...
Wet fine nissan filter becomes easily pulp (I am not speaking while u use it, but simply testing the paper). Fram paper fabric is superior, moist has 'no effect'. This tells smtg about structural quality. For aiflow, VG is asthmatic, Fram flows better - my experience, I have not measured. For sieving particles, nissan may be better as it feels finer. My guess is, Fram lives longer. My humble opinion: at least Nissan & Fram are ok.
Also one has to see, that NISSAN may use various filtermakers products. So as we talk of -one- nissan filter, we still may speak of different products.
For the filtering, & particle emission properties one should not beleive mine or enybody elses opinion; but seek lab test results. Pls smbdy google and present here... For other properties -opinions, one must try to find best.
Old Nov 10, 2005 | 04:36 PM
tripleGmax's Avatar
im using a monsterflow cone filter. got a great price on it.
my03maxima
Jul 28, 2024 07:40 AM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
