Do i have a bad mafs?
Old Nov 13, 2005 | 06:46 PM
Shift_my vq's Avatar
I've had the most frustrating problem with my 89 se lately where it won't rev past 2500 rpm about half the time when I'm driving it. I have a buddy that has a 91 se 5 speed as well and his car runs fine. I put his mafs on my car and it still did it. But granted I put it on and drove it around the block and straight back so it didn't give the car much time to realize it may have been fixed. It just seems to much of a kowinky dink that my car won't rev past 2400 rpm. Suggestions Ideas Comments???
Old Nov 13, 2005 | 07:01 PM
maxitech's Avatar
Had the same problem today. Check my post down the list.
Old Nov 13, 2005 | 07:02 PM
subs1000w's Avatar
pull codes 1st then well go from there
Old Nov 13, 2005 | 07:13 PM
Grace_Imports's Avatar
Here'e a quote straight from the FSM...
If the airflow meter output voltage is below the specified value, the ECU senses an air flow meter malfunction. In the case of a malfunction, the throttle sensor substitutes for the air flow meter. Although the air flow meter is malfunctioning, it is possible to start the engine and drive the vehicle. But the engine speed will not rise more than 2,400 rpm in order to inform the driver of fail-safe system operation while driving.
The other posts pretty much cover it. Check your connector and try cleaning it first and that may fix it.
Old Nov 13, 2005 | 07:24 PM
decus's Avatar
when you swaped out the MAF did you disconnect the batt to clear the ECU?
Old Nov 13, 2005 | 07:31 PM
subs1000w's Avatar
you dont have to, as soon as the ecu sees the correct voltage from a good maf it will go back to normal (i know this because i had a maf go bad on me)
Old Nov 13, 2005 | 08:55 PM
decus's Avatar
I would still rather clear the ECU...only takes a min and can help in some circumstances.
Old Nov 13, 2005 | 09:02 PM
Ok i'll pull codes and i'm going to the local u pull it tomorrow cause It's only 10 bucks for a used mafs there. My other question is right around this same time my fans stoped working. The motor revs up when the motor starts to reach the temp where the fans should turn on like it's trying to compensate for them being on but they don't come on. I've checked all the fuses and made sure there was no loose relay's??
Old Nov 15, 2005 | 09:10 PM
ebaker's Avatar
Seems like if the MAF was bad a known good one would have fixed it. Have you checked the fuel filter?
Old Nov 15, 2005 | 10:44 PM
maxitech's Avatar
What is the typical life expectancy of a MAF?
Old Nov 16, 2005 | 05:32 AM
internetautomar's Avatar
mod or sell?
about 10 minutes in an electrical storm
TallTom
57
Oct 14, 2025 05:16 PM
chisam14
Nov 6, 2018 08:56 PM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
