Replaced Axles and now....
Old Nov 25, 2005 | 03:21 AM
CyMax's Avatar
Ok to start with the drivers side axle worried me from the beginning. When I picked it up I didnt notice the axle nut was smaller than the origonial. So I called a mechanic friend, he assured me he had seen that before and as logs as the splines matched up not to worry about it. So I spalled it in filled up the tranny and took her for a test drive. Now the worry begins. There is a noise comming from the drivers side like heck, ummm sort of like when you have a loose lug nut or a warped rotor. A rubbing noise that seems to correspond with wheel roptation. Any ideas?? I'm about ready to take it to the garage and suck up the charges. HELP!!!
Old Nov 25, 2005 | 05:12 AM
internetautomar's Avatar
mod or sell?
did you tighten up the nut correctly?
did you torque down the lug nuts evenly and to spec?
Old Nov 25, 2005 | 05:47 AM
Matt93SE's Avatar
STFU n00b!
pull the axle nut off. measure the diameter of the new axle compared to the old one.
they might have given you a VG axle, which looks almost identical, but is about 0.1" smaller diameter.
Old Nov 25, 2005 | 08:03 AM
Jeff92se's Avatar
I'm needing a caw
Old Nov 25, 2005 | 02:14 PM
CyMax's Avatar
I just used a digital caliper to measure each axle, sure enough the drivers side is smaller. I was in a hurry and didn't write down the decimal differance, but that sure seems like it's the problem. I only drove it mabye 3 blocks then parked it after I heard the noise, that short of a trip wouldn't hurt the splines in the tranny or the wheel bearing would it?
Old Nov 26, 2005 | 12:12 PM
blackandwhite's Avatar
To them I'm like an idol
It might be that little thin dust shield that goes on the back of the rotor
Old Nov 26, 2005 | 12:26 PM
CyMax's Avatar
Guess what?? I sent the part back through my friend and sure enough, add Carquest to the list of parts stores that have the part #'s reversed for the drivers side axle. Thanks for the advice fellas, I'm on the way to swap them out and with anyluck I can move on to the next fix. Oh and GO WOLFPACK (20-14 over Twerps)!!!!
vingodine
45
May 21, 2016 12:46 PM
kingw323
20
Oct 21, 2015 08:36 AM
Starrider
Sep 17, 2015 07:26 AM
PH98I30
Aug 20, 2015 04:25 PM
classymax420
Aug 6, 2015 06:35 PM
