VE Axle Replacement
Old Nov 25, 2005 | 08:50 PM
Travis92se's Avatar
VE Axle Replacement
I replaced my driver side axle today and I was just wondering how tight the clip on the end of the axle will hold the axle in the tranny. I thought it popped into place but I can still move the axle in and out of the transmission a couple of millimeter (very little). I know I have the correct axle and it is completely identical to the one it is replacing. Any thoughts?
Old Nov 26, 2005 | 07:08 AM
MrSector9's Avatar
You have to REALLLY WACK that axle into the tranny. Get the spines lined up strait and give it a wack
With mine (drivers side also) I had to get a friend to help me, Hold it out strait,push in on it to taek the play out of the CV joints, we then put a 2x4 against the end and uses a 5lbs sledge to get it to finnaly pop in.
oh i forogt get kinda underneath the car to see how the seal protector and where the seal runs on the axle shaft to see how far it goes in.
Old Nov 26, 2005 | 08:04 AM
bhunter's Avatar
I thought I had the right axle too and the car wouldn't even move. There can be really small differences.
Old Nov 26, 2005 | 04:41 PM
internetautomar's Avatar
mod or sell?
so who has some REAL GOOD pictures of the correct axles, maybe some dimensions, spline counts ETC.
I'm trying to gather data so I can make sure I'm putting the right axles up on my site.
Old Nov 26, 2005 | 05:29 PM
CyMax's Avatar
And that is why you will always get our $$$$$
Old Nov 26, 2005 | 05:47 PM
Greeny's Avatar
¯\(°_o)/¯
Here are my 92 ve manual driver side pics..spline count is 29 each side..Not sure if they are "REAL GOOD" though..
Old Nov 26, 2005 | 08:16 PM
mod or sell?
on the double splined side (tranny side)are both sets 29 spline or is one 29 and the other 27?
also diameters would help if possible
Old Nov 26, 2005 | 09:53 PM
Travis92se's Avatar
Sorry, didn't get any pictures of the axles. But another question, should the axle fit right against the axle seal? Also, when the clip catch the axle will not move in or out anymore right?
Old Nov 27, 2005 | 05:06 AM
Greeny's Avatar
¯\(°_o)/¯
The outside set is 29,the inside set is 31 splines..
For acurate diameters i would need a micrometer...I don't have one..
Old Nov 27, 2005 | 02:45 PM
mod or sell?
Yes and pretty much
vingodine
45
May 21, 2016 12:46 PM
kingw323
20
Oct 21, 2015 08:36 AM
Starrider
Sep 17, 2015 07:26 AM
PH98I30
Aug 20, 2015 04:25 PM
classymax420
Aug 6, 2015 06:35 PM
