high rpm when idle on ve
Old Nov 29, 2005 | 02:42 PM
red-line-racer's Avatar
my max just started to idle at high rpm i check the throttle cable and i see nothing what could cause this??? thanks 4 the help
Old Nov 29, 2005 | 02:47 PM
vansskaterfreek's Avatar
your IACV (idle air control valve) might be stuck open...so basically clean it out with air intake/throttle body cleaner
Old Nov 29, 2005 | 02:48 PM
internetautomar's Avatar
mod or sell?
is that when it's warm or when it's cold (motor temp)?
Old Nov 29, 2005 | 02:50 PM
it dosent change it stays like that hot or cold
Old Nov 29, 2005 | 02:57 PM
mod or sell?
what exactly is it idling at?
have you checked for codes yet?
I'd also check the coolant temperature sensor for proper functioning
Old Nov 29, 2005 | 03:14 PM
its just a littel over the#2 and check motor light is not on
Cliff Clavin's Avatar
Way out West
My guesses would be IACV or coolant temp sensor, but there are still other possibilities.
Check for codes and a temp sensor is code 13.
If you look at the inside of an IACV, it doesn't do a lot of good to try and clean it out while it is still bolted on the car.
I suggest buying new gaskets for both the TB and IACV, then taking them both off and give each a thorough cleaning.
Old Nov 29, 2005 | 03:16 PM
where is the IACV exacly located at???
Old Nov 29, 2005 | 03:41 PM
mod or sell?
the CEL/SES light doesn't always go on even in cases of a problem.
in the stickies is the directions on how to pull the codes from the ECU
go there before you take apart your IAC
Old Nov 29, 2005 | 03:43 PM
Greeny's Avatar
¯\(°_o)/¯
Vacuum hose off/broken..
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
