The following does not work; is it related?
Old Nov 29, 2005 | 09:37 PM
gapboi210's Avatar
The following does not work, is it related?
Keyless entry pads are dead.
Security System is dead.
Trunk light does not work.
The light on the gear indicator does not work.
None of the lights come on that are on the doors.
'The dome light works, the gauges and climate control light up.
Power windows and locks work.
History of the car, it was broken into, the non-bose unit was stolen and as well as the rear speakers. The car sat for about a year, and then a new motor was put in it. All the fuses by the drivers side seem ok. Can this all be led to one source?
Old Nov 30, 2005 | 12:24 AM
decus's Avatar
I would get a FSM, a wiring diagram and start tracing wires in the doors. Check ECU codes? Check groundings? Check corrosion?
There is not much anyone can do to help you with electrical problems over the net unless someone has had exactly the same problem.
Old Nov 30, 2005 | 07:54 PM
gapboi210's Avatar
ok, do these share different fuses. Like, is the dome light and the lights on the door panel on the same fuse? Or do all these power wires group in a common place? If they are all located in a very close location I could check there.
Old Dec 1, 2005 | 04:49 AM
internetautomar's Avatar
mod or sell?
I highly suggest you get the FSM for the car as all answers are contained in there
Old Dec 1, 2005 | 05:10 PM
gapboi210's Avatar
I fixed it!
Old Dec 1, 2005 | 05:11 PM
mod or sell?
you gonna say how?
Old Dec 1, 2005 | 05:12 PM
maxitech's Avatar
yes, do tell...
Old Dec 1, 2005 | 10:36 PM
Mattster's Avatar
its clearly a secret he is going to keep to himself.
Slamrod
Sep 3, 2015 07:38 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
kenc15
Aug 5, 2015 08:29 AM
