Rear Window not working?
My rear window is not working at all. I can not control from the driver (master control panel) side or the single switch at the back where the window is. I did not hear any noise so what could it be? I have no problem operating other three windows either from the driver master control or at the door where the window is.
My guess the problem lies in the area of 1) Ellectrical issue 2) the motor and 3) regulator. How can I figure which one is the bad one.
Thanks.
Thanks.
Ok. Replaced the main control with one from the junkyard ($17.50). It still did not work. Open up the side pannel and notice the wire harness is not connected. The stupid mechanic whos worked on it before did not connect it when putting it back. It took me over 3 years before I noticed it this week.
Ok Ive got a window problem here, thought Id hijack this topic. The rear drivers (RHD!) window goes down by itself. It goes up and down ok, so its not the regulator, but randomly winds itself down when driving. I can stop it by locking the windows, and put it up with the master when it goes down. I was thinking faulty switch, but not sure if its rear or master. Thoughts?
You are heading in the right direction. It must be a problem with the switch or switches . The master or the one at the window is the question here.
If you got time just switch out the switch from Driver rear window to the Passenger rear window. If that still happens then it must be the master switch. Other way is buy both the master and a single window switches from a junk yard and replace both.
So for me, it was caused by the master switch getting shorted out.
If it's not the switch http://www.geocities.com/bracecraig/...regulator.html
Huttig2009
09-25-2015 03:31 PM
jerrod99_se-l
08-27-2015 08:27 PM
