Simple no-start
Simple no-start
I walked up to my car today, put the key in the lock, turned it, and only the driver side door unlocked when normally all of the doors unlock. I open the door and the factory alarm sounds, and of course it won't start even after the alarm's beeping stops. My guess is that the key is not disabeling the alarm when I unlock the doors, so the car doesn't wanna start. Gotta resolder the door locks or somethin? Everything was fine yesterday, but since it was pretty cold here the past few days (25-35 F) I figure the locks just froze up. I tried a genius experiment by spilling some hot water around the locks area to maybe wake them up a bit, no work. Where should I start in correcting this problem? Thanks alot.
Something interesting to note that when I pulled the horn fuse to shut her up, the high beams stop flashing and the "Security" warning light never comes on again. Seems like the whole Anti-theft system does not wanna respond without the horn available, except the car still doesn't wanna start, and I hear a stupid clicking sound coming from the fuse box.
You want me to snap a pic of the rod and lock cylinder?
Does anybody else got any ideas on how I can maybe bypass this anti-theft alarm so I can start my car and maybe use it? Or just fix this problem all together?
Man bhunter, I wish you responded sooner. Thanks anyway. Luckily I was fiddeling around earlier today and accidently noticed by opening the trunk you can trick the alarm and got her started. Thought I was the sh*t, until I read your post, heh
So it's really the driver side sensor? Where is it? Easy to replace/cheap? What to do?
Brian, I snapped some shots of the ring around the lock cylinder, maybe you can see something?
I hope I got the right shots.
![](http://img410.imageshack.us/img410/5406/drivlock6vz.jpg)
Heres a more clearer shot of the cylinder.
![](http://img410.imageshack.us/img410/3841/drivlock23qj.jpg)
Everything looks okay down there. Except the rod feels kinda loose that connects to the cylinder with the pink plastic holding it. Same on the passenger side.
![](http://img410.imageshack.us/img410/8608/drivrod6gc.jpg)
Quick shot of the passenger side lock cylinder, since I been having the problem Im having with the drivers side at the passenger side since I bought the car where it only opened itself and non of the other doors from the outside.
![got me](https://maxima.org/forums/images/smilies/ne_nau.gif)
![](http://img410.imageshack.us/img410/9072/passlock8ab.jpg)
Yeah, I read the alarm system on our cars is pretty worthless, but disabeling it kinda feels incomplete if I want everything to work on the car the way it did when it was new. What would you recommend my next step to be to get everything workin right? I've read through the old threads of similar problems to mine, but Im still confused on what exactly is done to correct the problem.. Resoldering door timer? Taking out the lock cylinder and touching it in all the right places? Everyone seemed to come to the conclusion of just getting rid of the thing. Thanks.
It's definitely the door unlock sensor(the black plastic thing around the lock cylinder). I had the same problem and replaced it with one from a 91. Only problem now is that whenever I unlock the driver's door, all the locks also unlock.
With the old unlock sensor, I had to turn the key twice for all the locks to open. Even with the one I got now, it does it sometimes. The passenger side sensor still needs two turns to unlock all the doors.
It is common on a lot of cars that the key opening the passenger door unlocks all doors and turning the key twice in the driver's door unlocks all doors. The logic is that if you open the passenger door you're going to end up opening the driver's door next and if you open the driver's door first you don't necessarily want the other doors open.
You can get it from a junkyard. Go to Craig Brace's page and read the how to for the door lock LED. It has the instructions for taking apart the door. If you can't find one, let me know. I have access to a parts car.
Originally Posted by Tarzan
In my car I have to turn the key twice in both front doors to unlock all doors. 2c
![NutKick](https://maxima.org/forums/images/smilies/nutkick.gif)
Also about the junkyard unit.. I don't know, since these things seem to crap out often, I might as well go for some new ones, instead of having to revisit this issue or a similar one a few thousand miles down the road or so.
Here's the exact link: http://www.geocities.com/cbmaxima/ma...oorhandle.html
Originally Posted by fatboyslim86440
this has happened to me thought it was something else
all my locks dont unlock any more from the driver side
and now my dimming light doesnt work any more
i could use some help too
Kyle Cisneros
Kyle Cisneros
Mahmuth
09-25-2015 10:08 AM
