Starting Problems
Old Dec 7, 2005 | 09:33 AM
Starchild2K2SE's Avatar
Starting Problems
I have a 92 third gen, gxe. Sometimes when I try to crank the car I just hear a clicking sound from the front, which sounds like its coming from the starter. I keep trying and I will just go "click", "click", "click", and nothing, But eventually it cranks over and starts. Sometimes the car starts right up, but most of the time it just clicks and I have to try starting it for 5 minutes before it finally does. Does anyone have any idea what is causing this to happen? Ignition? Starter? Fuse? Lemme know fellas, and does anyone else have this problem? Thanks.
Old Dec 7, 2005 | 11:16 AM
Greeny's Avatar
¯\(°_o)/¯
You need to buy a starter....
My starter did the same thing before it died....
Old Dec 7, 2005 | 02:12 PM
Everytime I buy a starter this happends. Could it be because im getting rebuilt starters? I think im going to nissan to get a nissan starter, im tired of these cheap rebuilt ones that im getting.....any other suggestions?
Old Dec 7, 2005 | 02:45 PM
decus's Avatar
Check battery and all your ground connections. If you have a spare batt from another car try it and see if it makes a difference
Old Dec 9, 2005 | 03:54 AM
DaWifey's90's Avatar
what can my max do for me
i got a rebuilt from autozone with no problems - and i have the warranty for insurance...they're easy enough to put on so i couldn't really justify a "new" one
Old Dec 11, 2005 | 04:46 PM
Mexi-Spice's Avatar
Me Too
I have the same problem, and my starter is about 4 months old but rebuilt. But somehow it stopped doing it. Dont know why. But I would stay away from the rebuilt starters
Old Dec 28, 2005 | 09:09 PM
GXEllent's Avatar
Here's how starters have been designed before WWII - the Max is no different. Since I don't know how much you know, here're the main principles - ignore it if you already know this stuff:
When you turn the ignition key, you're actuating a solenoid/relay combo (an electrically powered, heavy-duty switch) that's attached to the top of the starter motor. When the solenoid works properly, the switch makes contact and sends full battery current to the starter motor, which will then engage with the flywheel and turn the engine at about 300 RPM, enough to start it.
The "switch" inside the solenoid casing is usually a heavy copper disc that the solenoid whams against two terminals, closing the starter motor circuit. Because the current is high, there is usually arcing when contact is made, and that can cause carbon deposits, pitting, etc. on the disc and switch contacts. It prevents current from getting to the motor.
The "click" you hear is the solenoid actuating, and then nothing happens because the disc and contacts are dirty from arcing, pitting, etc. preventing the motor from running.
The switch is in the shape of a disc so it can rotate over time and keep presenting clean surfaces to the contacts. This extends the life of the thing. If you keep clicking the solenoid it often will whack against the contacts enough times to finally close the motor circuit. However, this is usually a degenerating problem that only gets worse with time.......
GXEllent
Old Dec 29, 2005 | 06:21 AM
GXEllent - that was a great write up...mad props...
Starchild2K2SE i read this over again and it might not be ur starter...at least it might not be ur starter's fault. i used to do failure analysis for some ford products (yes i was really busy - i've heard all the jokes). i remember having one truck that ate up starters...and we were putting in brand new ones in too. in any case, turned out either the flexplate was not stamped to specs or it was damaged during assembly. the busted teeth and warped ring tore up the starters....it's a stretch....but it might be something u many wanna explore
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
