when does maf max out?
Originally Posted by crzycav86
Anyone know how much hp the 3rd gen maf can support?
Also, where is the search feature on this forum?
Thanks.
Thanks.
Thanks.
Thanks.
That's gay.
Anyone else? I've read something like 300-350hp on from people that have used them on 240sx's, but I'd like to verify with you guys since it does come from your car. Does anyone have a definite answer?
Originally Posted by maxmaxima91
on my stock MAF, i dynoed 271 WHP and the maf was reading 5.16 volts at 6000 rpms. So ... yea that was maxed out.
Jeremy
Jeremy
That's the same as 240 mafs I guess I'll max this maf too. Thanks for your help everyone. See yall later!!
That's gay.
Still think it's gay????
Maxima mafs only read 5 volts?
They are faster than maximas. lol
Granted its like comparing apples to oranges... but anyways.
better watch who's forum you insult.... You may be buddy buddy with mikepeed, ameen, and the other *****es on H240, but I own this place....
a 3gen Maxima MAF will support roughly 300hp. if you're looking at more power than that, your best bet is a Z32 or J30 maf.. after that its a Cobra MAF.
and FYI, all MAFs are designed on a 0-5V scale. anything more than that and the ECU doesn't know what to do with it. the difference between all of the units is simply the airflow it takes to get to that maximum 5V reading.
I was not insulting this forum in the slightest, just the search function. I still don't think it's a good way to run a forum. All it will do is increase redundant threads(unless you guys don't mind saying the same thing over and over), reduce member loyalty, annoy people, and increase the number of useless members.
Originally Posted by mtcookson
Actually, stock for stock the Maxima's are ever so slightly faster. That's a 90 VG against a 95 240SX. The 92-94 VE against one would toast it. Its all in the power to weight ratios. If memory serves, the Maxima's hp to weight ratio is slightly higher than the 240SX however the torque to weight ratio of the Maxima is way better than the 240 (the VE only gets better).
Originally Posted by ColombianMax
I like 240sx' but most of them I see are riced out...giving me the impression you might be rice...anyway you got
Originally Posted by lanedrifters
Get a q45 maf.. supposedly a 700hp maf..
Actually a q45 maf will support less Hp than a z32 and J30 maf will. It is larger, but much more sensitive. If i remeber right its good to about 375, or somwhere around there.
Jeremy
I like that smilie.
Anyway, I drive a 240sx, so that's why I mentioned them. They are faster than maximas. lol
Also, I noticed, my MAF for the maxima are significantly bigger than the sr20's.
You shouldn't worry about the MAF on a bolt on maxima. It will definately be fine. If you decide to go boost and increase the IM pressure, you should increase A/F abilities with a z32 MAF. It's just like with the 240s man, if you have no serious mods, then the stock will do. If you decide to add more boost with higher flowing injectors and some form of A/F management then of course a larger MAF will be beneficial.
You have a point in that regard, but who keeps their car stock?
Going by above, the Q45 is supposed to handle less than the Z32 maf. The best upgrade would probably be the Z32 maf or maybe the Cobra maf (pretty sure that's the one used. I think it was mentioned above).
Only someone who must be either broke, simply not a car enthusiast, or outright crazy
litch
123
01-04-2024 07:01 PM
TallTom
50
07-08-2022 09:54 AM
04-16-2020 05:15 AM
magiconthetire
10-26-2015 09:03 PM
