Need some quick advise
Old Dec 10, 2005 | 03:58 PM
maxima92se's Avatar
My car is a 92 ve and the car starts up and everything but when the car finally warms up, the car starts to bog really really bad. it starts at about 1500rpms to about 3500rpms, so basically when i floor it, the car stutters bad between this range. i really dont know what it is. the car only does that when you feed it with a lot of gas. does anyone know what causes this. It started yesterday after the snow fall in Auburn, Ma on my way from work.
all help greatly appreciated.
Old Dec 10, 2005 | 04:01 PM
vansskaterfreek's Avatar
maybe it is a bad injector dumping too much fuel into your motor????? check your spark plugs for weird colors.....like if one is black and the others are a whiteish (or normal) then the black spark plug shows you that your injector may be bad
Old Dec 10, 2005 | 04:02 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
also could be a bad knock sensor making the motor run too rich or lean......but ill second the bad injector to check first......
Old Dec 10, 2005 | 04:11 PM
Greeny's Avatar
¯\(°_o)/¯
Everyone will say knock sensor,so i will throw it in here for safety sake...which it may very well be the problem.....
I had the same issue with my 94 ve...Grounding the vtc selonoids solved the problem...
Nobody else on here that i know of has had this issue with their vtc's...I guess i am special..............Ed..
Old Dec 10, 2005 | 04:37 PM
maxima92se's Avatar
I guess i will check the injector and see. thanks guys.
Old Dec 10, 2005 | 04:56 PM
internetautomar's Avatar
mod or sell?
I'm gonna go with knock, because injectors are normally most noticeable at idle
Mar 12, 2020 12:06 AM
NewMax03
Oct 7, 2015 08:27 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Noela
Sep 26, 2015 08:22 AM
