Passenger side CV AXLE
Old Dec 10, 2005 | 12:57 PM
majordan's Avatar
Has anyone had this problem before.......Took out the passenger side axle today, I remove the three bolts from the bearing housing pulled firmly and the axle came out. My question is......How do I remove the bearing housing part from the old axle to put on the new one? Was it suppose to stay attached to the old axle? and if so, do I get it remove from a machine shop and pressed on the new axle before installation or is there a way I can get it off here in my garage, also the little ring thing at the end of the axle is still on the old axle, does it screw off?
Thanks for your help..
Mark
Old Dec 10, 2005 | 03:05 PM
vansskaterfreek's Avatar
i would say that oyu need to get a machine to press the bearing out....... go to an auto parts store and spend $60 for a new one.. mind as well get two while you are at it.
Old Dec 10, 2005 | 03:32 PM
majordan's Avatar
Why do I need two bearings. I was under the impression that The bearing that's on the old axle can be pressed off and re-used on the new axle shaft.
Also does any auto shop carry the bearing and is there a special name that I need to use to relate to that bearing.
Mark
Old Dec 10, 2005 | 03:37 PM
there is only one bearing.....i was talkign about you should replace both axles if you are only gonna replace one...... if u r gonna get a new axle.. you mind as well get a new bearing (should already be on the axle)
Old Dec 10, 2005 | 03:52 PM
majordan's Avatar
Buying the new axle was the first thing I did, unfortunately there was no bearing attached to the new one, that's way I am inquiring about getting the old one pressed off the the bad axle and onto the new one.
Mark
Old Dec 10, 2005 | 03:56 PM
thats weird.. where you get the axle from?????? you might have to take the axle to a shop to press that seal back into place.....but i am not 100% about this.... if i am wrong.. please, someone enlighten me
Old Dec 10, 2005 | 03:57 PM
96ItaliaSE's Avatar
il massimi bassi
i did my axles it was pita...i had to get transmission seals as well
Old Dec 10, 2005 | 04:13 PM
majordan's Avatar
Auto Zone.....I have done business with them before, very dependable. The shaft looks like the correct one, but the is no bearing attached to it. I did take it back and ask the saleman should the bearing be attached to the new axle but the only thing he could tell me is that that was the correct part number. Like I said the new axle matches up to the one I pulled out other than having a bearing attached to it. I need some help out there please....
Mark
Old Dec 10, 2005 | 04:45 PM
dantegl's Avatar
I got my passenger side axle from auto zone as well and i'm 110% sure that there was a new bearing on there. Positive.
Old Dec 10, 2005 | 05:02 PM
majordan's Avatar
Thanks I will go back and raise a little hell. Question for ya.....Did you reuse the little metal ring at the end of the shaft that mounts up to the seal?
Mark
Old Dec 10, 2005 | 06:32 PM
blackandwhite's Avatar
To them I'm like an idol
Mark
I reused mine becuase it fit better than the new one...
The Wizard
24
Oct 1, 2015 08:47 PM
BrandonCause
Sep 14, 2015 10:41 PM
Colossus
Sep 9, 2015 05:46 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
maximusrising
Sep 2, 2015 09:55 AM
