Broken Crossmember.....has this ever happened to you?
Old Dec 10, 2005 | 06:26 PM
blackandwhite's Avatar
To them I'm like an idol
Yikes.....
Before......
Old Dec 10, 2005 | 06:27 PM
And...After....Courtesy of Blehmco....
Old Dec 10, 2005 | 06:32 PM
Greeny's Avatar
¯\(°_o)/¯
It is a good thing matt lives close to you or you'd be skrood dude....
Old Dec 10, 2005 | 06:37 PM
Well....(trying not to sound like a commercial here, but) .....Maybe not.....something tells me that this may soon be availible for anyone with a core , and a mailbox.
Old Dec 10, 2005 | 08:27 PM
vansskaterfreek's Avatar
matt93se broke his also i think
Old Dec 10, 2005 | 09:05 PM
subs1000w's Avatar
man this is happening more and more as these cars get older and older the next time i have mine off im reinforcing it
Old Dec 10, 2005 | 09:29 PM
maxmaxima91's Avatar
nice.. Thats exactly why i did this, Before i turboed
I welded 1/8 inch thick pieces of metal to the top where you see, and the entire bottom.
Old Dec 12, 2005 | 09:51 PM
stock should be fine right??????? well besides the WSP?????
Old Dec 12, 2005 | 11:16 PM
95turbo gxe's Avatar
Well its not a good pic but yep got one too. I said I was going to re inforce it while back but did not get to it but I need to sone.
Old Dec 13, 2005 | 12:45 AM
nismosleeper's Avatar
Not really; I have cracked mine while having a WSP, full exhaust, and intake.
Old Feb 22, 2006 | 03:50 AM
crazy4maxima's Avatar
any ideas ve or vg crossmember is universal? Where to get one? thanks
Old Feb 22, 2006 | 09:51 AM
Jeff92se's Avatar
I'm needing a caw
I bet because everyone jacks up their cars under the x-member doesn't help either. I have a good VE x-member for sale. Let me know
Old Feb 22, 2006 | 01:16 PM
goon9's Avatar
I set the jack under the oil pan
Old Feb 22, 2006 | 04:25 PM
internetautomar's Avatar
mod or sell?
I lift it up by the rocker panels
Old Feb 22, 2006 | 06:51 PM
i held my VG and VE crossmembers up to eachother and they looked identical
Old Feb 22, 2006 | 08:28 PM
maxitech's Avatar
So if I was to, say, removing the oil pan to put a new gasket on, where would I support the engine from?
Old Feb 22, 2006 | 09:18 PM
seenoz's Avatar
Support
You can take two 4X4 blocks about 1 and 1/2 feet long and put them on the strut towers. Get a 4 foot pece of tubing about 3 inch by 3 inch squared and 1/8 thick wall. Put it on top of the 4X4 blocks across the motor. Jack up the motor and put a chain on one end of the motor. Then around the the tubing and to the other side of the motor. Then you can lower the motor and unbolt the crossmember.
SEE NO Z
Old Feb 22, 2006 | 09:36 PM
maxitech's Avatar
Yes, that would probably work, but how about some place I can support the engine from underneath?
Old Feb 23, 2006 | 11:36 AM
PunkFriday's Avatar
Power Dorifto Extraordinaire!
if matt is reinforcing these crossmembers, i will want to jump onto the bandwagon. if you are around, throw out a price or update your site man!
Old Feb 23, 2006 | 12:15 PM
Matt93SE's Avatar
STFU n00b!
It takes a couple of hours to do the labor on them... I'll do them for $100, including return shipping to anywhere in the states. (that's exchange. I don't have any cores available, so you have to send me one to fix first.)
and yes, this is pretty common for those of us that drive the cars hard..
Also, both VG and VE are the same crossmember. all 89-94 are same so just get whatever they have at a junkyard.
pics?
http://blehmco.com/pics/car/drivetrain/crossmember/
Old Feb 24, 2006 | 01:24 AM
Well my mech was able to get the crossmember and i found out that the rear engine mount was torn out of place, all said and done 100 for the beam,80 bucks for the rear motor mount.
Old Feb 24, 2006 | 10:19 AM
Matt93SE's Avatar
STFU n00b!
that's pretty cheap....
Old Feb 24, 2006 | 02:26 PM
PunkFriday's Avatar
I suspect this can be done as a preventative, not just as a repair? or will that be pointless?
Old Feb 24, 2006 | 02:39 PM
kcidmil's Avatar
Hmmm, time to raid the local junkyard. That way I can send down a few of them.
Old Feb 24, 2006 | 02:45 PM
Jeff92se's Avatar
I'm needing a caw
Why dig through the bone yard. $100 shipped.
Old Feb 24, 2006 | 03:28 PM
Greeny's Avatar
¯\(°_o)/¯
This is my thoughts also....Time to bust out the welder again...
Old Feb 24, 2006 | 07:55 PM
Aaron92SE's Avatar
NWP Engineering.com
You support the motor by the crank pulley. Just put a block of wood on the crank pulley and support the motor with a jack.
Old Feb 25, 2006 | 12:15 AM
Loco7's Avatar
i am no expert but is that a jack stand under the oil pan? and GOON did i read you right you jack your car under the oil pan? I'm no expert but I'm pretty sure that's not the best place to jack a car by or support it by either. Just thought I'd through my 2 cents out
Old Feb 25, 2006 | 07:13 AM
Matt93SE's Avatar
STFU n00b!
Nah.. I've repaired both mine and Jayson's (the pics above) and then reinforced them. just weld the thing back together and then grind the high spots down and weld a piece of plate steel on top of the weakest points. 2 hrs later, clean and paint and it's done.
Old Feb 25, 2006 | 05:39 PM
mod or sell?
stick welder FTL!!!
Old Feb 25, 2006 | 05:51 PM
Greeny's Avatar
¯\(°_o)/¯
stick welder FTL!!!
Old Feb 25, 2006 | 05:58 PM
mod or sell?
you didn't get to see the welder in the shop
Old Feb 25, 2006 | 06:00 PM
Greeny's Avatar
¯\(°_o)/¯
They wouldn't let me in...
I guess they heard about my welding skills...
Old Feb 25, 2006 | 06:04 PM
mod or sell?
yeh, only 1 redneck welder per shop
Old Feb 26, 2006 | 07:07 AM
Cliff Clavin's Avatar
Way out West
MattComet was telling me about this when we were installing my new tranny yesterday.
Crap, I am getting a little tired of breaking everything on these cars just by adding a few power mods.
Good thing Blehm is around to beef things up for us...
Old Feb 28, 2006 | 10:09 PM
no blemco in my area
Old Feb 28, 2006 | 11:03 PM
Way out West
They have this thing now called s h i p p i n g.
Old Mar 1, 2006 | 07:55 AM
Matt93SE's Avatar
STFU n00b!
I have accounts with DHL, UPS, USPS, and Fed Ex...
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
mkaresh
Mar 12, 2018 06:48 PM
Need help
23
Oct 2, 2015 08:56 AM
