power lock problem
Old Jan 7, 2006 | 02:01 PM
slickblack94's Avatar
power lock problem
ok new problem. the power locks on my 94 se sometimes quit working all together, them sometimes it will work for months and then it will quit again. now it has been a week and they still dont work. any ideas what this might be? any fixes? ty in advance dan w.
Old Jan 7, 2006 | 02:21 PM
Greeny's Avatar
¯\(°_o)/¯
The door lock timer is most likely the cause of your lock trouble...Just replace it...
Old Jan 7, 2006 | 02:36 PM
thanx man. Is this hard to take out? looks like its up in the dash. i really want to fix this but dont have the funds to pay someone to do this. do I have to take anything out to get to it? thanks for info
Old Jan 7, 2006 | 02:47 PM
Greeny's Avatar
¯\(°_o)/¯
It is fairly simple to get to it....You got to take off the panel under the steering wheel to access the unit..It is to the right of the steering wheel behind the panel...
Old Jan 7, 2006 | 04:04 PM
red-line-racer's Avatar
its just a few screws off and replace and Ur done!!! e.z but also make sure your getin the right one cuz when i had replace mine i noticed a few maximas that had 1 connector goin to the timer and there was very few that had 2 connectors goin to the timer some here might know why is that????
Old Jan 7, 2006 | 04:50 PM
Josh's Avatar
where are you going to get the timer from?
i'd say first resodder the board i did mine last week and my locks are back to working fine now, just an idea to save you a few bucks and if you were going to get one from the junkyard i would say definatly try this first.
Old Jan 7, 2006 | 08:50 PM
alextothestars's Avatar
yes; finally fixed mine a few weeks ago. the hardest part is removing the bottom dash part...which isnt hard at all.
as i said before, the connection was bad at the same pole as the one used in the write up with pictures (look very carefully..youll wonder why you missed it once you see it); solder became grainy and non conductive according to temperature outside. seems to be a common problem.
one of the easiest fixes for such a great payoff (i love using the keypads now!)
Old Jan 22, 2006 | 05:10 PM
donowprod's Avatar
was it difficult to solder
Old Feb 1, 2006 | 09:28 AM
TeacherKP's Avatar
thanks for the info. that was what I needed as well.
Old Feb 16, 2006 | 06:31 AM
mahatma's Avatar
Have to jack another thread since I CANNOT SEARCH or POST A NEW THREAD
^ Any help with that would be great.......
But here's my question:
I'm trying to reprogram the code for keyless entry. I got the number from the "digital touch entry control unit" behind the glovebox - the middle number sequence of the 3 lines engraved on the unit.....
Can anyone tell me exactly how to reprogram it? I don't know the current code. I had a Nissan technician explain it once, but he was very unsure and when I went home to try it, his method didn't work. Thank you very much!
Old Feb 16, 2006 | 06:35 AM
Josh's Avatar
http://forums.maxima.org/showthread.php?t=413179
http://forums.maxima.org/showthread.php?t=378748
Old Feb 16, 2006 | 07:09 AM
mahatma's Avatar
Thanks for the links, it all makes sense now.
I scoured the FAQ and didn't see that once.....woops.
Old Feb 28, 2006 | 09:20 PM
jrogers's Avatar
Just wanted to thank everyone for this thread. I've been having on and off problems with by power locks for years and have just kind of ignored it. After seeing this thread, I pulled out the door lock timer and checked the circuit board. At first, everything looked fine, but then I pulled out a magnifying glass and found a crack all around one terminal. I resoldered it and - voila - I have power locks again. Thanks.
Old Feb 28, 2006 | 09:36 PM
Black92GXE's Avatar
Boomer Sooner
quick & easy fix! Did mine last weekend and love being able to lock my doors again!
i had never worked on soldering a circuit board & did this fine - works like a charm!
definately worth the litte bit it took to unbolt the bottom panel and pull the board and resolder it - didn't cost a thing!
Old Mar 1, 2006 | 08:11 AM
aussie983's Avatar
Very easy fix.
I hope this helps:
http://www.thewardrops.com/maxima/
lowpost99
Oct 26, 2025 06:53 PM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
Hailstatejig
Sep 2, 2015 06:52 AM
